Pcm bad?
Old 08-27-2023, 11:17 AM
Dan11288's Avatar
Dan11288
Dan11288 is offline
Yeah I must of damaged reinstalling valve body trying to set park rod. I will get another one
  #42
Old 09-06-2023, 07:30 PM
Dan11288's Avatar
Dan11288
Dan11288 is offline
Just to update I have found and fixed the problem with 1763 code. I changed tcc harness and solinoid due to damaged wires in harness still no good. I plugged in harness and solinoid outside of transmission and still 5 volts on signal wire. I pushed down the plug as hard as I could and voltage dropped to .38 on signal wire I let go of plug back to 5.17 volts. So it's the connector from the main harness to the transmission, changed it out and all good. Was a nightmare to troubleshoot especially because the wires were all ringing out perfectly from connector but I guess the connector was not seating completely down.
  #43
Old 09-07-2023, 09:36 AM
HeyYou is online now
Dodge Forum Administrator
Received 3,305 Likes on 3,050 Posts
Thanks for the update.
Quick Reply: Pcm bad?
