Pcm bad?
Old 08-18-2023, 09:03 PM
Dan11288's Avatar
Dan11288
Dan11288 is offline
Default Pcm bad?
I am a new member in need of help with possible short or pcm problem. I have a 2001 ram 1500 with 5.2l. I Last year i had a p1740 and replaced governor pressure solinoid and torque converter filter and fluid. Truck ran and shifted fine. I am currently getting p1763 and p1762 code. I replaced governor pressure solinoid and transducer again and also installed transgo shift kit in valve body. I cleared codes but as soon as I start truck check engine p1763 within 10 seconds. I tested pin 4 the signal wire for gov pressure on trans harness plug and am getting 5 .14 volts with plug disconnected from transmission I should only be getting I volt or less I think. I searched for a short in wiring and found nothing. When I unplugged pcm c2 I tested voltage at pin 29 on pcm and am getting 5.14 volts is this normal or is my pcm bad. Sorry for long post
Old 08-19-2023, 10:52 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,305 Likes on 3,050 Posts
With the trans disconnected, you shouldn't be seeing ANY voltage on pin 4..... You have either a short in the harness, or the PCM has gone bad. Test resistance between pin 4 and pin 2, with ignition off, C2 and trans unplugged. Should be infinite, if it is, bad PCM, if it isn't, short in the harness.
Old 08-19-2023, 11:42 AM
Dan11288's Avatar
Dan11288
Dan11288 is offline
No continuity on pin 4 to pin 2
Old 08-19-2023, 11:49 AM
HeyYou is offline
Bad PCM.
Old 08-19-2023, 12:28 PM
Dan11288's Avatar
Dan11288
Dan11288 is offline
Thanks for your help. Are pcms plug and play if same engine or do they have to be programmed to vin#
Old 08-19-2023, 12:32 PM
Dan11288's Avatar
Dan11288
Dan11288 is offline
Also would a resistor work on wire to pin 4 to bring voltage in range
Old 08-19-2023, 01:26 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is online now
For 2001, I believe the PCM will need to be programmed to the VIN.
Old 08-19-2023, 03:04 PM
HeyYou is offline
PCM needs to be programmed to the VIN, and no, a resistor won't work. That's pressure feedback from the sensor. The PCM needs to know that for proper trans operation.
Old 08-19-2023, 05:13 PM
Dan11288's Avatar
Dan11288
Dan11288 is offline
Thanks for I will order PCM and hopefully all good.
Old 08-19-2023, 05:14 PM
Dan11288's Avatar
Dan11288
Dan11288 is offline
Thanks for help
Quick Reply: Pcm bad?
