My 01 Ram 5.2 won’t start but turns over fast as it ever did..
Old Sep 14, 2023 | 06:45 AM
  #31
Moparite's Avatar
Moparite
You can check the bolts holding the crank sensor in, Behind the passenger head at the bell housing. If you want to post a video put it on utube and link it here.
Old Sep 14, 2023 | 07:52 AM
  #32
Put some chemicals on that bolt, tap it lightly with a hammer. Do that for a couple days, then try and take it out.
Old Sep 15, 2023 | 02:46 AM
  #33
2001RamGuy's Avatar
2001RamGuy
Default Thanks Moparite 👍
I have squeezed my hand back there and the bracket that is part of the sensor assembly is tight to the block.
It was hard to explain in my previous message but what I meant was is there a chance the plastic sensor part came lose from the metal bracket part of its assembly..
I guess I just have to pull on the wires a little and see if it’s lose from it’s own bracket it’s attached to..
thanks very much.
Old Sep 17, 2023 | 04:50 AM
  #34
2001RamGuy's Avatar
2001RamGuy
Default Maybe a coincidence !!
At daybreak on Friday morning when it was covered in dew and a bit cold it started for 10 seconds then shut off, then I restarted it and it ran for a minute or so, then I restarted it again and it idled for 45mins before I turned it off.
Today in the afternoon I tried to start it when it was warm and dry and it started first try but was idling so low it shut off.
I started it again and it ran for an hour.
I even got the nerve to back it out of my driveway and drive a Klm. & thankfully I made it home.
I let it run in my driveway for another 20 mins after I got home and it was ok.
There’s some weird clicking noise coming from the front of the transmission in the pump area.
Could it be that the PCM sees the trans is in limp mode and it’s shutting down the eng ???
I’ve had no first gear (automatic) for a year or two..
or does anyone think it could be a bad Distributor cap ?
The plugs and wires are new but the cap and rotor probably have 80 thousand Klms on it..
thanks very much 🙏🏻🙏🏻
Old Sep 17, 2023 | 10:22 AM
  #35
Moparite's Avatar
Moparite
What's that in miles? 49.7K thanks google. Is it a brass or aluminum insert cap? It wouldn't hurt to take a look! The aluminum ones seem to discriminate way faster than the brass ones.
Old Sep 18, 2023 | 01:38 AM
  #36
2001RamGuy's Avatar
2001RamGuy
Default Thanks Moparite !!
My apologies I should have known better than talk Metric. Sorry
Yeah I guess since I’ve had a new cap and rotor here for 2 or 3 years it’s time to install it.
The new stuff I have is brass but the old stuff that I put in around 10 years or 50,000 miles ago is just the Standard average stuff.
i have been putting it off because it’s such a hard job.
Where the distributor is and it being a 4x4 with a 6 inch suspension lift I guess I am just going to have to lay ontop of the rad and engine from the front and reach back there.
Not going to be easy for a guy who is getting close to 60 with a bad back and 3 wrists operations. But I’ve got to take a look inside that cap and rotor before just replacing the cam and crank sensor on a guess..
We had a ton of rain yesterday afternoon so I went out to see how the old girl would do.
It started for 5 seconds then died. I restarted it again and it ran for 15-20 mins and then died.
So I decided to hold the idle at around 900-1000 Rpm. After 20 mins it seemed to have lost spark or fire for a millisecond but because I had it held at that higher Rpm it didn’t shut completely off.
It just seemed to lose spark for a instant but by the time the Rpm was down to around 500 it caught it’s and kept running and didn’t die completely.
It seems to just lose spark for a very short period of time randomly.
Yeah that’s probably not going to help you guys with your suggestions maybe because it maybe still could be a number of things but I just thought i would mention…
Thanks very much Moparite I appreciate your and HeyYou trying to help me out 🙏🏻🙏🏻
Old Sep 18, 2023 | 06:43 AM
  #37
Theslyfox's Avatar
Theslyfox
Default Could just be.
Originally Posted by 2001RamGuy
I’ve been having trouble with my left front signal/light for a year but that’s not a big deal. I checked the bulb and the socket and everything is good. In the last couple of weeks there’s been occasions when every light in the dash comes on all at once.. Eng lite, abs lite, parking brake lite, (all of them)
I scanned it and all I got was a EVAP code. Even though the transmission has been unable to go into first gear (automatic) and there used to be a code for that issue too but it didn’t show up when I scanned it yesterday.
Now it won’t even start anymore and just cranks over forever and doesn’t even try to start.
Something weird is going on and I don’t have the patience or days and days and days to diagnose and backtrack everything.
Could it be a bad ground somewhere or do I just happen to have 3-4 problems all coming up in a short period of time ?
thanks to anyone who knows more than me. I’ve had this truck for 22 years and I don’t want to scrap it because of a simple thing that I’m not aware of TY
I guess maybe as someone told me “”I should clean up all grounds and pull the computer off the firewall and make sure it’s getting a good ground too 🤷🏻‍♂️
Edit….. it just started fine at 5am when the whole vehicle is colder and covered in early morning dew, but wouldn’t start yesterday in the day when it was 32degs Celsius and dry outside 🤦🏻‍♂️
Cranked over just fine on both occasions but didn’t start until 5am and it’s damp and colder 🤷🏻‍♂️
engine crank sensor!
Old Sep 19, 2023 | 05:30 AM
  #38
2001RamGuy's Avatar
2001RamGuy
Default Thanks Theslyfox…
Yeah I guess from what some other ppl have said that is probably the most likely problem.
If it was a bad cap or rotor I would imagine it would run rough and misfire instead of just idling perfectly and then just dying for a second or suddenly and then starting back up again.
At first it would die and I could not get it to restart for hours but now it restarts again as soon as I turn the key.
I do have a real main crank seal problem so maybe oil has been on the crank sensor so long it’s messing with it.
Even though an old mechanic friend of mine says “oil on it will not matter because it is magnetic” hmm.
But maybe after having oil on it for years it has caused it to short out or something.
I’ve watched videos and tried to reach back behind the eng where it is located.
Not looking forward to trying to change it but I’ll give it a try I guess. I may as well put on a blindfold because that’s how it’s going to be changed..
thanks for your help/suggestion 🙏🏻🙏🏻
Old Sep 23, 2023 | 07:24 AM
  #39
2001RamGuy's Avatar
2001RamGuy
Default Thanks HeyYou, now i am having this problem you mentioned.
Could your scanner still talk to the pcm?
I decided to try a drive it last night. I got around 2500 feet and it cut out for a millisecond but kept running.
500 feet later and it died so i coasted into a parking lot.
Tried to restart it and checked for spark and fuel pump activation.
I had neither. No spark and no fuel pump cutting in.
So I plugged in my scanner and I got what you mentioned (no communication with scanner)
I tried the old school 3 fast turns of the key to the Accessory position and got “(NobuS)” in the odometer.
10 mins later it started up and I made it back home but it tried to die on the way home once,, but before rpm got to low it caught itself and kept running.
While pulling in my driveway it wouldn’t idle by itself and stalled so I had to keep my foot on the gas.
What do you think would cause intermittent (no spark and no fuel pump cutting in,, and Nobus)
Thanks very much I really appreciate your help.
Old Sep 24, 2023 | 08:19 AM
  #40
Could be a failing PCM......
