Replacement Headlights
Old Sep 18, 2023 | 09:18 PM
4dptr's Avatar
4dptr
Default Replacement Headlights
I'm sure this topic has been beaten to death. I searched but couldn't find the answer I'm looking for. My 02 2500 needs new headlights, including the bulbs (9004s). There's a 'ship' ton of headlights out there, Ebay, Amazon...etc. What headlights have others installed that they've been happy with. I see a lot have water leaks, poor fitment, not good quality. I just want an OEM style or maybe blacked out housing, but still stock style replacements. So this is not a sport but 2500 with single bulb headlight. Any help with this greatly appreciated. Thank you.
Old Sep 18, 2023 | 09:35 PM
AtomicDog's Avatar
AtomicDog
Post
If you can, go with sport headlights. You get 2 headlight bulbs per side and a lot more light output than the non-sport single bulb headlights. The sport headlights fit in the same space as the non-sport headlights. You can find them at rockauto.com and several other outlets. The only other item you will need is a relay harness to take the higher electrical load off of the known weak headlight switch. You can find the sport headlight relay harness at LMCtruck.com or here - https://ceautoelectricsupply.com/hea...ion-relay-kit/ - Just FYI, there are also threads out there to make-up your own relay headlight harness, if you feel handy and so inclined.
I converted my subpar single bulb headlights to the sport style headlights and would never go back to the single bulb setup again.
Old Sep 19, 2023 | 05:53 AM
I got two sets of headlights from AM-Autoparts.com. Stock style, said they don't come with bulbs, but they do..... Fit like stock, bolt right in, are ADJUSTABLE like stock...... First set still looked brand new when I sold the truck. Second set still looks brand new, and I still have the truck.
Old Sep 19, 2023 | 07:51 PM
magnummaniac's Avatar
magnummaniac
Not sure if they’re interchangeable but Dorman sells a set on Amazon for $65 that I just installed on my 1998 1500. Easy install, came with bulbs, and can be adjusted. Zero complaints so far
Old Sep 19, 2023 | 11:04 PM
4dptr's Avatar
4dptr
So in installing replacement headlights is it advantageous to remove black bumper guard for ease of access for R&R? I've seen a lot of videos were installer eventually just knuckles the light in place, some even using a screwdriver for leverage with fender squeezing the light inplace. Also would it be beneficial for light adjustment as well?.
Old Sep 19, 2023 | 11:09 PM
magnummaniac
I’ve seen multiple approaches from sagging the bumper to nothing at all. On mine, I didn’t remove anything and slowly worked them into place. I did manipulate the bumper trim by pulling it out and away but didn’t have to remove it. I can’t speak for others, but, I for one really appreciate being able to adjust my headlights
Old Sep 20, 2023 | 06:17 AM
I loosened the bumper bolts so it would drop down a bit to make it easier. On my 96, I didn't have to move anything at all......
