Automatic transmission
Old Oct 6, 2023 | 06:57 PM
63Bguy's Avatar
63Bguy
Default Automatic transmission
I found this in the transmission pan when I dropped it. does anybody know what it is?
Old Oct 6, 2023 | 09:38 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
I believe that is a part of the band strut mechanism. When you adjust the transmission band, the screw pushes that part against the band strut to adjust the band's tension. Not sure if its for the reverse band or the kickdown band, but that's what it looks like to me. - got a photo of the inside of the transmission above the transmission pan (where the bands and drums are)? That should show where that part should be and possibly other parts are missing...
With that part not in-place, I suspect your transmission isn't shifting properly, either in reverse or going forward?
Old Oct 7, 2023 | 07:16 AM
Moparite's Avatar
Moparite
Old Oct 7, 2023 | 07:57 AM
63Bguy's Avatar
63Bguy
Thank you, I did find out this morning what it was. I appreciate you answering me, Yes, the Transmission will not move at all once I put it into Gear. Do you know If I am able to remove the shift body I will be able to get it back into Position with removing the tranny? Thank you for your Help
Old Oct 7, 2023 | 08:37 AM
Shouldn't even need to drop the valve body to put it back in. You WILL need to properly adjust the bands though.
Old Oct 7, 2023 | 02:23 PM
AtomicDog's Avatar
AtomicDog
If that's the only part that fell into the pan, it should be pretty easy to re-install that part back onto the band. As HeyYou mentioned, the band will need to be properly adjusted. Also, check the band strut to make sure it isn't bent.
