Transmission spit oil but no leak
Old Nov 2, 2023 | 11:46 AM
AngeryDogeOwner's Avatar
AngeryDogeOwner
Default Transmission spit oil but no leak
This recently happened to me. I drive a 1997 dodge ram 1500 4x4 with the 5.9 magnum. While driving up and down a lot of steep hills I had pulled over to check something. When I got out I seen a noticeable about of atf fluid leaking from my bell housing onto my exhaust. In a nearby town I parked my truck for a couple hours and when I came back there was a small puddle of oil on the ground. I checked my fluid levels and all was fine. Up these hills I was driving 55mph at 3200rpm and engine temperatures only reached around 205. I even ran my heater uphill because I recently replaced a lot of parts including this transmission. But it has been a few days now and I don't see a single drip under my truck, no codes, and everything runs perfectly fine. Oil levels still remain the same.
Old Nov 2, 2023 | 12:51 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
Welcome to the forums.
Weep hole behind torque converter. Did the vent tube get installed? Pan bolts torqued properly? The oil dipstick tube not installed properly, O-ring missing?
Old Nov 3, 2023 | 11:40 AM
AngeryDogeOwner
I'm not entire sure about the weep hole. This transmission was supposed to be a bolt on and go installation with it pre oiled as well. I do remember the transmission pan gasket leaking right off the bat but crawling under there and with a ratchet tightened up the bolts and it stopped leaking. all new sensors and everything on the transmission. no check engine codes, still no oil dripping down currently, and shifts/drives perfectly fine. I'm just guessing it got hot and burped some fluid?
Old Nov 3, 2023 | 12:31 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
My thoughts also.
Old Nov 3, 2023 | 01:04 PM
AtomicDog's Avatar
AtomicDog
Post
Originally Posted by PR1AWRet
My thoughts also.
Especially if it was fully pre-filled with transmission fluid. I've never heard of that before..
Old Nov 3, 2023 | 03:01 PM
Probably over-filled. Wouldn't hurt to check the fluid though.
Old Nov 4, 2023 | 10:16 AM
Moparite's Avatar
Moparite
It's not a weep hole but there is the vent, It's at the top of the pump body.
Old Nov 4, 2023 | 01:05 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
Weep hole/Vent. A lot of mud boggers and racers plug this hole up and put the vent further back on the case.
Old Nov 5, 2023 | 08:51 AM
Which strikes me as a REALLY good idea...... being able to put a hose on it, and route it up as high as you can, to avoid having the trans suck water/mud/othernastystuff is a VERY good plan.
