New Steering Gear and Power Steering Pump
Old Nov 6, 2023 | 09:52 PM
1SaltyGreenBean's Avatar
1SaltyGreenBean
Default New Steering Gear and Power Steering Pump
I seen a ton of info on bleeding the system, but not much on installing a complete system. So can i fill the steering gear through the return line prior to hooking hoses up to the pump? Just to get some fluid in the gear box. I mean the more i get in the less air I have to deal with, right? No? So what are yall's opinion or process to to acomplish this. I'm getting to old to deal with a 22 year old beach/mountain truck. Meaning the fasteners are exceptionally fun to deal with. Greatful in advance for any suggestions or tips!
Old Nov 6, 2023 | 11:33 PM
AtomicDog's Avatar
AtomicDog
I've had no issues just replacing the power steering gearbox and power steering pump, filling the pump reservoir with fluid and turning the steering from lock to lock a few times with the engine running to bleed/fill the system to get it functioning properly.
Old Nov 7, 2023 | 05:52 AM
Moparite's Avatar
Moparite
And use power steering fluid not atf.
Old Nov 7, 2023 | 06:52 AM
I use the same method as the dog above, but, I have the front end up off the ground when I do it.
Old Nov 7, 2023 | 11:17 AM
1SaltyGreenBean
Thanks ya'll. I can always count on your knowledge and expertise! I got it jacked up, rechecked the lines and have the POWER STEERING fluid ready. Let you know how it turns out.
Old Nov 7, 2023 | 02:10 PM
Fill the reservoir, then turn the steering lock to lock a couple times, Engine OFF. Recheck fluid level, top it off, then start the engine, and cycle the steering a few times.
Old Nov 7, 2023 | 07:47 PM
1SaltyGreenBean
Thanks to you all. Got it bled down and did a test drive. I was surprised that it only took just less than a quart and a half of power steering fluid. Now at cold reading, it's just above the line by about 1/4''. Should I suck that down to the line or give it a few more days and recheck. Thanks again!!!
Old Nov 7, 2023 | 08:41 PM
Keith_L's Avatar
Keith_L
Meh, that much across the surface area of the Sag reservoir ain't much. Probably half a turkey baster.
If it's significantly overfilled it'll just puke it out the cap..
It's up to you -- leave it or pull it down -- probably doesn't matter
Old Nov 10, 2023 | 11:27 AM
specks's Avatar
specks
Just did mine as well. Gear, pump, hoses, pitman arm. Couldn't get the brace back on though.
I used atf instead. should i change it out or, leave it?
Old Nov 10, 2023 | 11:33 AM
specks's Avatar
specks
I read on here that atf was ok to use!
