1998.5 2500, Can I put Fog lights on their own switch? They come on with parking and
Old 11-30-2023, 11:20 PM
Joe.G's Avatar
Joe.G
Joe.G is offline
Default 1998.5 2500, Can I put Fog lights on their own switch? They come on with parking and
Hi, Right now the fog lights come on as soon as parking lights are turned on Position 1, they will stay on when the low beams are turned on but turn off when the High beams are turned on. Am I able to separate them so i can control when they come on? I believe they are factory set up.
Thanks
Old 12-01-2023, 07:17 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,391 Likes on 3,131 Posts
Your headlight switch should control them, but, all it does is 'enable' them to be on with the low beams. I do believe there is a relay in the PDC to provide power. Install a switch to control that relay, and you have control of the fogs.
Old 12-01-2023, 08:07 AM
Joe.G's Avatar
Joe.G
Joe.G is offline
Gotcha, I will have to try and find the relay, electric is not my strong point. I would not mind using a factory style switch which I believe was a 1 year only and was near the air bag, not sure how I would wire this.
Old 12-01-2023, 08:25 AM
HeyYou is offline
The factory switch just enabled the relay, the fogs will still only be on with the low beams, and off with the high beams. It was incorporated into the headlamp switch for the 98.5 update. I think ya pull it out to enable them, or some such.
Old 12-01-2023, 08:40 AM
Joe.G's Avatar
Joe.G
Joe.G is offline
I just would like to be able to control them like my 04, I can have parking lights by themselves or add the fogs same with Low beams.
Old 12-01-2023, 04:14 PM
HeyYou is offline
You should already be able to do that...... Do you have the pull switch for the headlights, or the rotary switch?
Old 12-01-2023, 06:47 PM
Joe.G's Avatar
Joe.G
Joe.G is offline
Pull switch.
Old 12-01-2023, 09:30 PM
HeyYou is offline
Pull switch.
There there should be a separate fog lamp switch in the dash.... Can you post a pic??
Old 12-02-2023, 08:33 AM
Joe.G's Avatar
Joe.G
Joe.G is offline
I purchased this,
https://www.ebay.com/itm/186159855935
My switch looks like this
https://www.ebay.com/itm/35406843961...Bk9SR5bG16uFYw
Old 12-02-2023, 09:07 AM
HeyYou is offline
Yeah, then you should have the foglamp switch on the Passenger Air bag thing there....
Quick Reply: 1998.5 2500, Can I put Fog lights on their own switch? They come on with parking and
