My 01 Ram 5.9 magnum Trans problem
Old Dec 4, 2023 | 05:22 PM
kang's Avatar
kang
So the shift lever is stiff when things are cold?
yes here is winter. and when I first start up
transmission is stiff
Old Dec 4, 2023 | 05:26 PM
kang's Avatar
kang
Originally Posted by AtomicDog
Kang, where are you generally located and how cold does it get in that location?
from Korea and here -3c .
My truck park underground parking lot.
Old Dec 4, 2023 | 05:28 PM
kang's Avatar
kang
Originally Posted by MtnTow
Ask them to send you a picture of the transmission fluid they used.
My shifter gets stiff at -35c but not that bad.
ok I need ask what used fluid my transmission.
Old Dec 4, 2023 | 05:41 PM
AtomicDog's Avatar
AtomicDog
That transmission calls for ATF+4 fluid. Hopefully, that is what the shop used to refill it.
Old Dec 4, 2023 | 07:20 PM
-3 c really isn't that cold. It gets stupid cold here, well below zero F.
Why the shifter is stiff when its cold out though, that's just weird..... Might try hitting the linkage with some spray white grease..... exercise it a bit, see if it loosens up.
