My 01 Ram 5.9 magnum Trans problem
Old Dec 4, 2023 | 03:01 AM
kang's Avatar
kang
Default My 01 Ram 5.9 magnum Trans shift problem
Hi my Ram 1500 Trans is problem
3days ago my trans oil seal change and trans oil also change in shop.
and yesterday first cold start my car.
cold start my trans is neutral => drive cant moving my gear lever
only neutral => drive moving is problem P-R,N,1,2 and drive => neutral also no problem
but gear lever pull and down go to Drive and push moving my gear lever.
after acceleration my car trans shift is no problem.
and My truck drive after trans oil is hot very soft moving my trans gear lever Neutral => Drive moving also smooth.
i cant find google and any search forum
what is problem my trans
Thanks
Old Dec 4, 2023 | 06:45 AM
Take it back to where you have the work done. See what they have to say.
Old Dec 4, 2023 | 07:01 AM
kang's Avatar
kang
Today I go that shop.
they say "cold trans and cold oil is have that problem"
they say "cold weather.. Oil is sticky.."
Is true??
I can't believe because I saw some YouTube videos that cars cold weather is no problem
Old Dec 4, 2023 | 07:05 AM
It would have to be REALLY cold for thick fluid to be a problem. My truck starts/runs/drives/shifts just fine, even when it is -20 farenheit..... I think they are feeding you a line.
Old Dec 4, 2023 | 07:15 AM
kang's Avatar
kang
Default Then what is problem ??
this car is 4 years ago trans overhaul already.
now just trans oil seal Change.
I just find Google can't find this problem
I want fix this problem
Old Dec 4, 2023 | 07:34 AM
My problem is, I don't really understand what you are describing. Is english not your first language?
Old Dec 4, 2023 | 08:52 AM
kang's Avatar
kang
sorry my first language is not English
I bought this truck 1month ago.
and that time I saw maintenance list.
my trans is already all fix 4years ago.
3days ago my trans oil seal and trans oil change after my trans have a problem.
Before parts change transmission was no problem.
truck is cold start. my transmission is neutral => drive cant moving my gear lever
but gear lever pull and down and moving to D and gear lever is push. gear lever is moving.
If trans oil is hot very smooth moving my trans gear lever.
Shop say "cold trans and cold oil is have that problem"
I think They are lying
Old Dec 4, 2023 | 04:20 PM
So the shift lever is stiff when things are cold?
Old Dec 4, 2023 | 04:55 PM
MtnTow's Avatar
MtnTow
Ask them to send you a picture of the transmission fluid they used.
My shifter gets stiff at -35c but not that bad.
Old Dec 4, 2023 | 04:57 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
Kang, where are you generally located and how cold does it get in that location?
