Sony XS-R 6946 in 96 dodge ram 1500
Old Dec 30, 2023 | 01:41 AM
Green_Dodge's Avatar
Green_Dodge
Default Sony XS-R 6946 in 96 dodge ram 1500
Hello, I was just wondering if anyone had ever put the sony XS-R speakers in their Dodge, because I tried, and they aren’t working. Any tech tips or help would be great, Thank you!
Old Dec 30, 2023 | 03:36 AM
Moparite's Avatar
Moparite
Did the old speakers work? They are no different than any other speaker so if they are hooked up they should work.
Old Dec 30, 2023 | 05:49 PM
Green_Dodge
Default They did work
They worked fine, and then I put on one new one, and it doesn’t even make a sound
Old Dec 30, 2023 | 06:17 PM
Do you have the infinity sound system in your truck?
Old Dec 30, 2023 | 07:13 PM
Green_Dodge
Yes, I do
Old Dec 30, 2023 | 10:09 PM
There is likely some additional wiring for the speakers that you won't be using then.... Front speakers should have had amps on them? Amp for the rears is stashed elsewhere, I think.... I believe the infinity system outputs from the head unit are pre-amp outs.... not line out... But, as you replaced the head unit... hard tellin' what outputs are going where at this point.
Old Dec 30, 2023 | 10:30 PM
Green_Dodge
Thank you very much, I hope I can figure it out!
Old Dec 31, 2023 | 06:10 AM
Moparite's Avatar
Moparite
Look at the audio section for your truck here, It will be a lot easier.
Old Jan 2, 2024 | 11:43 PM
kevinb70's Avatar
kevinb70
only important part is in bold
Not sure if applies to the 1996, but did you have an amplifier mounted on your OEM front speaker? I think to turn it on you need the power antenna wire connected to your receiver even if you dont have a power antenna.
Anywho... Now that the speakers are gone...
It's best to just run new speaker wire to your speakers because with the amp-on-speaker design, the wiring isn't straightforward. You will be one less headache just running new wire.
plus the stock wire is thin
Myself, I have speakers ordered from crutchfield. I went with 6 1/2" w/adapter plate because I don't exactly want the extra bass in the door. Also have 80mm deadening ordered for the door skins, speaker enclosures to protect from rain, and already have a set of pre-cut tint as I'm going to do all at once. Pull the glass and do tint inside so wind and door edges don't ruin another pre-cut set. Just finished with my double DIN conversion and now got 7" screen. Nav and bluetooth and more to bring her into the 21st century. Haven't mounted/wired up the dashcam and backup cam
