Valve Body Rebuild or Whole Trans Rebuild
Old Jan 5, 2024 | 07:40 AM
1998RamMan's Avatar
1998RamMan
Check valve is in the cooler line, so, really doesn't have much affect on pressure. If it gets clogged, it prevents fluid flowing to the cooler, and the trans overheats. The RE transmissions monitor trans temp, and if it gets too hot, overdrive gets disabled first, if it continues getting hotter, the trans temp light in the dash will come on. 95 and older trucks, trans temp sensor was external, and an option.... so, that particular bit of code wasn't always there.
Exactly what I was looking for, thanks for answering in depth. I’ll try to setup my trans temp gauge this weekend and see what’s going on. I was thinking about putting the test probe in one of the side test ports since I don’t have a trans pan with trans temp port. How does that sound?
Old Jan 5, 2024 | 07:57 AM
The ports won't always have pressure, so, your gauge may not always read the correct temp. There are a variety of ways to handle that, most common, is have the temp probe on the outgoing cooler line. That gives you the best idea of what trans temp really is. Of course, it isn't 100% accurate, tends to read a few degrees low.... Just keep that in mind when you gauge starts approaching 200 degrees.
Old Jan 5, 2024 | 08:14 AM
1998RamMan's Avatar
1998RamMan
Originally Posted by Moparite
If you have gauge/s you can test it yourself, I wonder what the line pressure is?
https://atracom.blob.core.windows.ne...0/2000_154.pdf
Thanks a ton. I’ll buy a set of gauges this weekend and test those ports
Old Jan 5, 2024 | 08:17 AM
1998RamMan's Avatar
1998RamMan
awesome, thank you. Unfortunately looks like most pans with the side trans temp ports are upwards of 200-300 bucks, so for now I’ll probably just do the outgoing line. Looks like I just get a T fitting, cut a chunk out of the trans line and stick the fitting on there?
Old Jan 5, 2024 | 12:53 PM
1998RamMan's Avatar
1998RamMan
question on this. How would I go about testing cooler line pressure where the check valve is, or is it possible to check pressure there?
Old Jan 5, 2024 | 02:57 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
You can change the pan to one with a drain plug pretty cheap - (
Amazon Amazon
In addition, you can drill your own port in the side of the pan to mount the temperature sender for a trans temp gauge. Just have to make sure the sensor won't hit the valve body..
Old Jan 5, 2024 | 03:52 PM
1998RamMan's Avatar
1998RamMan
Originally Posted by AtomicDog
You can change the pan to one with a drain plug pretty cheap - (https://www.amazon.com/Premium-Trans.../dp/B07MXKPY67)
Got it. Yeah that was definitely an idea I had. Drilling into things that hold liquid is a bit scary lol. I’ll probably by another pan for cheap and find a quality plug kit and go from there.
Old Jan 5, 2024 | 03:59 PM
AtomicDog's Avatar
AtomicDog
Another option is to keep your eye out for a good used deep 46/47/48RE pan. I found a used ATS deep pan on Facebook Marketplace at a decent price, a lot cheaper than new..
Old Jan 6, 2024 | 08:08 AM
Moparite's Avatar
Moparite
Weld a (pipe thread) bung on the pan, With proper sealant it will not leak.
According to the print(flow chart) in the service manual the cooler line is "lubrication" 5-57 psi. There is no "port" for that but installing a "T" in the cooler line you would be able to test it.
