Swapping a Dana 70 drum brakes to Dana 80 disks brake on a 2000
Old Jan 24, 2024 | 10:21 AM
  #21
AtomicDog's Avatar
AtomicDog
Congrats! Setup looks to be the same as my disc brake Dana 60.
Old Jan 24, 2024 | 03:36 PM
  #22
That's a massive chunk of iron.
Old Jan 24, 2024 | 05:21 PM
  #23
AtomicDog's Avatar
AtomicDog
Probably takes several hefty folks to lift it. Hope someone had a tractor with a loader on it to place that rear in the back of your truck..
Old Jan 24, 2024 | 06:49 PM
  #24
That_red_dodge's Avatar
That_red_dodge
Well we didn’t have nothing to put that in, made a makeshift hoist with logs🥴
Old Apr 9, 2025 | 09:15 PM
  #25
yruconfused's Avatar
yruconfused
Originally Posted by That_red_dodge
Hi! I'm looking into swapping my Dana 70 drum to a Dana 80 disk brakes and i'm wondering if the dimensions are the same. Is it pretty much bolt-on swap? Or there is alot of parts that needs changing?
The drum and disc flange is different the disc holes are narrow and wide and not symetrical like the drum. The axle itself is identical. Do you have a disc brake 2001.5-2002 dana 80? If so can you please measure the spindle where the backing plate bolts to the flange, to the end of the threads? I want to do the opposite of what you want to do disc on drum. I believe that the disc measurement is about 6-3/4 where the drum is 6-1/4. I can get you the drum length on the spindle length. I know a guy that makes flanges to adapt one to another.
I have a brand new dana 80 Dodge 94-01 rear axle with carrier and 3:55 gears.
Get back to me and let me know if you can get that distance on the spindle. Thanks
Old Apr 9, 2025 | 09:16 PM
  #26
yruconfused
I misread you are trying to put discs on drum axle. Sorry.
Old Apr 10, 2025 | 06:38 AM
  #27
Moparite's Avatar
Moparite
Now who's confused?
Old Apr 10, 2025 | 11:26 PM
  #28
yruconfused
Originally Posted by Moparite
Now who's confused?
Who's not confused about any parts swapping adventures?
