Pulsating grind feont wheel
Old Jan 30, 2024 | 10:39 PM
Brendancrowley's Avatar
Brendancrowley
Default Pulsating grind front wheel
I have 2001 dodge ram 1500 4wd, ihad some issues with a growl pulsating at low speeds mainlybwhen turning the wheel left ir right. So replaced the front drivers side wheel hub assembly, upper and lower ball joints.
no i notice i have a pulsating growl almost like a dull grind at low speeds like 20 - 50 km/hr, when the wheel is straight,if i turn a little to either left ir right it goes away. I had new brakes brakes put on so they seem good, no shuddering when braking, the cv axel looked good.
so jacked up the tire and when spinning the wheel it seems like a little slight noise once a rotation coming through the brake drum area (hard to tell for sure). I checked the tire heat guars and doesnt seem to be rubbing. Wheel has no play in 6 to 9 a little play on the 9 to 3 but figure its tie rods.
i did notice that when i take the tire off i can pull the rotor in or out maybe about a 1/4 on an inch ( not sure if thats notmal) i out the wheel nut in and got the pin in and still looks ok.
could the brakepad or drum cause the deep vibration or got a bad wheel hub ?
regards in advance for any help
Old Jan 31, 2024 | 06:13 AM
Moparite's Avatar
Moparite
No not normal! You should not be able to move it at all.
Is the movement on this side or the other?
Old Jan 31, 2024 | 12:53 PM
Brendancrowley
I never tried looking at the wheel and the rotor. Could be that i dont have the giant 1 3/4 inch wheel nut tight enough,
i put torque wrench and set it to 180 lbs heard it click and the pin fits in. As long as the wheel is tightened up with the lug nuts it the rotor should sit pushed in and flush.
I just don't get the part if I turn the wheel slightly the rumble goes away it like the opposite of what people say with bearing problems.
Old Feb 1, 2024 | 01:35 AM
Keith_L's Avatar
Keith_L
Normal because your lugnuts squeeze the rotor between wheel hub and wheel itself. No lugnuts = loose rotor. The only thing keeping it there is caliper and pads at that point
Your axle nut sounds fine at 180 with cotter pin installed
You definitely have the '00+ brake parts and not '99 and earlier?
Old Feb 1, 2024 | 04:43 PM
Brendancrowley
I actually had the pads done at a professional shop, I'm gonna guess yes they seemed great when we picked up the truck.
the other thing I never mentioned was after doing the hub and ball joints, I noticed a noise going back and forth to the dog park and realized the lug nuts weren't tight they were actually hand turntable loose. Maybe forgot to finish tightening them with tire iron. Took a whole day to get the lower ball joint out , was ready to push that truck in the lake.
I noticed this time after taking the wheel off there was some metal filings on the caliber nut. Did i wreck my new hub ? Is there a for sure waybto tell if my hub is toast ? Could i have i have not got the brake drum back on proper, I just remived the entire drum.
The rumble is most noticeable when i take my foot off the gass doinflg around 50 or 45 km.
Old Feb 1, 2024 | 10:46 PM
ol' grouch's Avatar
ol' grouch
To be honest, your spelling is rather confusing. You evidently have something loose. The noise coming and going makes me wonder if you have a warped rotor. A shop might put on pads but if they didn't turn the rotor, you might have a warp and it will never go away. Are you finding ny marks on the inside of the wheel in question? That might explain metal particles on your caliper, if that's what you meant.
Old Feb 2, 2024 | 06:23 AM
Moparite's Avatar
Moparite
No drums, You mean rotors. Maybe posting some pics of what you have could clear things up.
Old Feb 2, 2024 | 12:42 PM
Brendancrowley
I googled warped rotos also, seems like there should be signs of that on the rotor like scraps wore in but it looks smooth. I will jack it up and take off the wheel again get some pics ir a video with the sound.
I had read about maybe being the front differential. If the sound goes away when its in 4x4.
but it's the turning the wheel and the noise goes away that throws me off..
Old Feb 2, 2024 | 02:52 PM
ol' grouch's Avatar
ol' grouch
Actually, a warped rotor can look totally normal. You need a dial indicator gauge to read the run out. I have seen heavy repeated braking wear the front pads at an angle. That will cause the caliper to grind on the inside of the wheel.
Old Feb 8, 2024 | 07:25 PM
Brendancrowley
Not sire what happened. But I put it into 4 wheel for a bit then back to 2 then back to 4 wheel and back to 2 wheel and the rumble is what seems like 98% gone. I think maybe a little rumble once in a while or might just be my imagination on a bad road in winter.
not sire if I needed to ongage the 4 wheel after re installing the cv axel or the front differential , But so far so good.
