Tire Pressure question
Old Feb 14, 2024 | 07:47 AM
  #21
Moparite's Avatar
Moparite
Yeah, but, then the nuts would rust up, and when you needed your spare, it would have become a permanent part of the frame
Use stainless steel hardware!
Old Feb 14, 2024 | 03:01 PM
  #22
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
I have 315/70/17 Maxxis RAZR MT load range "D". I run 36 PSI f/r. They are on American Racing AR172 BAJA AR1727885B Satin Black 17X8 5X139.7 with a 2 inch front leveling lift. Rear tires don't contact anything. Front tires rub the rear of plastic inner liner a bit. When at full lock l/r there in no rubbing. Mine is a heavy duty with another spring in the rear spring pack. I don't see the truck hauling anything heavy so that's where the load range "D" comes in.
I use chalk on the cross section of the 4 tires, roll it and check to see where the chalk came off and adjust air pressure till the chalk comes off the cross section of the tires.
Old Feb 14, 2024 | 03:35 PM
  #23
There are also temperature sensitive strips that you can lay across the tire. Hotting in the center, drop pressure a couple pounds. Hotting on the edges, raise pressure a couple pounds. Fussy, but, can be incredibly accurate.
