ABS codes 45, 47,65
Old Feb 10, 2024 | 08:41 PM
Mneukirch86's Avatar
Mneukirch86
Default ABS codes 45, 47,65
So after scanning my 2001, dodge ram 1500 I came up with ABS codes 45, 47,46 but haven’t been able to find a lot of information on what the issue is even though I’m assuming it might just be a requirement of me to replace the ABS module ?
Old Feb 10, 2024 | 09:06 PM
AtomicDog's Avatar
AtomicDog
Does your truck have 4 wheel or rear wheel ABS? Regardless, the codes should be in the service manual, I believe in the brake section with the ABS info - You can download a copy for your year truck here - https://dodgeforum.com/forum/2nd-gen...e-manuals.html
Old Feb 11, 2024 | 08:10 AM
Mneukirch86
so I’m trying to see if I can find a used ABS module but I’m not sure which number I need to make sure I match because there’s four numbers on the body one sticker says C1H95HO / 13451521 – D
and the other says P52010075AE / TXXBU114180854
Old Feb 11, 2024 | 12:32 PM
AtomicDog's Avatar
AtomicDog
Question
Does your truck have 4 wheel ABS or just rear wheel ABS?
Old Feb 11, 2024 | 12:38 PM
Mneukirch86
Since I do not see any wires going to the front wheels, I would have to say it’s a two wheel ABS
Old Feb 11, 2024 | 01:03 PM
AtomicDog's Avatar
AtomicDog
Is your truck 2WD or 4WD? You should be able to generate a build sheet showing your truck's options via this link - https://fcagroup.my.site.com/RAM/s/equipment-listing
I'm curious, as two of the codes seem to elude to issues with the left front of the truck, which would seem to say that your truck has 4 wheel ABS...
Old Feb 11, 2024 | 01:18 PM
Mneukirch86
I don’t see anything on that bill sheet that says anything regarding ABS
And yeah, I know it says left front but I don’t see any wiring that goes to the front wheels
Old Feb 11, 2024 | 01:32 PM
AtomicDog's Avatar
AtomicDog
Old Feb 11, 2024 | 01:34 PM
Mneukirch86
It’s a 1500 SLT Laramie. 5.9 gas. 4wd
Old Feb 11, 2024 | 01:52 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
If the truck has 4 wheel ABS, you can check the front axles behind the U-joint. There would be front wheel sensors to monitor the spinning axles. The front axle with ABS should have a tone ring on it like shown in the attached photo.
The part number you mentioned (P52010075AE) can be easily be searched via Google. By typing in "Mopar P52010075AE" I come up with this - https://www.ebay.com/itm/144524341511
