Rocker arms
Old Feb 28, 2024 | 07:56 AM
Gilmore96 ram's Avatar
Gilmore96 ram
Default Rocker arms
I’m just trying to see if I tightened the rocker arms right I tightened them until I couldn’t move it then turned it half a round more
Old Feb 28, 2024 | 07:58 AM
These are pedastal mount rockers. You torque the bolt to spec, and you are done.
Old Feb 28, 2024 | 08:04 AM
Gilmore96 ram
I havent really found anything on torque specs for the rocker arms
Old Feb 28, 2024 | 08:07 AM
Download the service manual for your truck from here. Procedures for R&R rockers should be in there.
Old Feb 28, 2024 | 08:16 AM
Gilmore96 ram
I didn’t really see anything on rocker arms
Old Feb 28, 2024 | 08:21 AM
Section 9. Go to the section for your engine size, and look for Rocker R&R. it's in there.
Old Feb 28, 2024 | 08:48 AM
Gilmore96 ram
16 ft lbs seems like a lot
Old Feb 28, 2024 | 08:58 AM
I thought it was 21??????
Follow the procedure, and it should work just fine. Though, I might be tempted to use a bit of lock-tite blue on the threads......
Old Feb 28, 2024 | 08:59 AM
Gilmore96 ram
What I saw on the manual for the 5.2l is 16
Old Feb 28, 2024 | 09:22 AM
Hhhmmm..... Not sure that is correct, everywhere I am seeing 21ft/lbs......
