crank no start
Old May 21, 2024 | 05:25 AM
  #31
Moparite's Avatar
Moparite
Now you need to check the output to the pcm. If you can take it to someone that has a high end scanner it's a lot easier. But it can be done with a meter. While you are at it check the coil and see if the readings are within spec. They are in the service manual.
Old May 21, 2024 | 08:28 PM
  #32
DJGreco's Avatar
DJGreco
https://www.youtube.com/watch?v=TXKf96wqaoU
should i check both the cam and crank sensors output to the pcm?
Old May 22, 2024 | 05:45 AM
  #33
Moparite's Avatar
Moparite
Yes, Both are needed for it to start.
