crank no start
Old May 20, 2024 | 02:29 PM
  #21
DJGreco's Avatar
DJGreco
Is it still throwing the same codes?
Yes same 5 codes
Old May 20, 2024 | 02:30 PM
  #22
DJGreco's Avatar
DJGreco
Originally Posted by Moparite
Coil, injectors and 02's get power from the asd relay. Are you sure you checked the correct wires since you said it has power at the coil?
I have power to the connector at the bottom of the coil but not the spark plug wire from the coil. Yes i checked the asd relay and where it plugs into it's getting power
Old May 20, 2024 | 02:40 PM
  #23
If the coil has power, the injectors should as well. Again, only for a few seconds at initial key on, and then only if the PCM sees the engine turning. (crank sensor.) If the injectors don't have power, there is a broken splice somewhere. Service manual will show you where they are all.
Old May 20, 2024 | 06:28 PM
  #24
DJGreco's Avatar
DJGreco
Alright now my injectors are working
Old May 20, 2024 | 07:52 PM
  #25
Do they still have power while cranking?
Old May 20, 2024 | 08:12 PM
  #26
DJGreco's Avatar
DJGreco
Neither my coil or injectors
Old May 20, 2024 | 09:02 PM
  #27
Bad cam or crank sensor, or bad PCM.
Old May 20, 2024 | 09:10 PM
  #28
DJGreco's Avatar
DJGreco
So i checked my crank position sensor then checked the voltage to it and it wasnt reading anything when do i get power to it at initial key on or only when it's cranking?
Also would any of these just stop working after a day on not driving it?
Old May 20, 2024 | 09:11 PM
  #29
DJGreco's Avatar
DJGreco
also i replaced my crank sensor
Old May 20, 2024 | 09:45 PM
  #30
DJGreco's Avatar
DJGreco
Nevermind the crank sensor is getting 6.6v at initial key on and crank
