Slow blinker
Old Apr 6, 2024 | 05:59 PM
KameronG11's Avatar
KameronG11
Default Slow blinker
I've got a 97 dodge ram 1500 and I have led tailights and factory headlights, my blinkers are super slow so I'm looking for a flasher that will fix it. Where can I find one?
Old Apr 6, 2024 | 06:00 PM
Sure it's not just the old one getting tired? Do you have any LED bulbs in the brake/turn signals?
Old Apr 6, 2024 | 06:08 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
I had a similar issue a while ago with my LED tail lights and installed an electronic flasher from Rock Auto.com. In addition, I pull trailers with LED lights, too. The new flasher helped a lot.
Old Apr 6, 2024 | 06:46 PM
KameronG11's Avatar
KameronG11
I'm not sure if that could be the problem or not. My headlight turn signals are just the regular type of bulbs and my tailights and tailight turn signals are both LED.
Old Apr 6, 2024 | 09:52 PM
AtomicDog's Avatar
AtomicDog
Are both sides blinking slow or just one side? Lastly, did the slow blinking occur after installing the LED tail lights & rear turn bulbs?
Old Apr 7, 2024 | 04:28 AM
HeikIlm's Avatar
HeikIlm
Those old relays are bi-metal type, which means there are two metal strips that heat up when current flows through them, they bend and circuit opens (light goes out). Being bi-metal, one bends more and the other resists bending, so when the circuit opens, they cool down and strips bend back to close the circuit, and cycle starts again.
Now, when filaments are replaced with leds, there's not enough load to heat the bi-metal strips as fast they used to, hence the slow blinking.
Old Apr 7, 2024 | 07:20 AM
Moparite's Avatar
Moparite
Exactly, Even if you mix bulbs the load will be less. Get a electronic flasher, They don't work off of any load from the bulbs.
Old Apr 7, 2024 | 08:46 AM
KameronG11's Avatar
KameronG11
What's a good electronic flasher to get?
Old Apr 7, 2024 | 11:52 PM
AtomicDog's Avatar
AtomicDog
I went with a Tridon. Standard parts works well, too.
