95ram 1500 5.2 skip
Old May 4, 2024 | 12:39 PM
oddone's Avatar
oddone
Default 95ram 1500 5.2 skip
I went on a 7 hr Rd trip yesterday (about 3.5hrs each way) made it where I was going just fine then about half way home it started running funky and seems to be skipping and now I believe due to that suddenly not shifting properly had recent (8mo) tune up and 3 mo ago replaced the pick up under the distributor cap has been running great until yesterday with no warning was running great then suddenly not. My friend that does most of my work think maybe the coil? It looks like it might be original and the truck has close to 290,000 miles on it
Old May 4, 2024 | 03:39 PM
Is it setting any codes??
Old May 5, 2024 | 01:29 AM
oddone's Avatar
oddone
don't know this is a 1995 pre obd2 and my check engine light i believe the bulb has been removed if i was able to read codes they would be the old basic 2 digit codes with very limited info
Old May 5, 2024 | 08:06 AM
Moparite's Avatar
Moparite
Put a bulb back in and do the key dance. Yea two digit codes but will give you a good idea what the problem is.
Old May 5, 2024 | 01:14 PM
oddone's Avatar
oddone
Yeah that would require taking the entire instrument panel out to figure which bulb plus i already know it has bad EGR and the only o2 is. Missing and cat is hollow but been that way for at least 5yrs with no problems
Old May 17, 2024 | 09:51 PM
oddone's Avatar
oddone
well finally got around to actually checking plug wires tonight by misting with spray bottle while running and the passenger side by the valve cover is at least one wire arching out so gonna talk to my guy that did the tune up to see if he remembers when it was done and if there is any warranty on the wires probably not but worth a shot. If not covered ill replace them next month just strange that it was running great then all of a sudden started skipping running like crap finger crossed
Old May 18, 2024 | 06:35 AM
Moparite's Avatar
Moparite
If the wires are el cheapoes they are problematic out of the box. Get a decent set of 8 mm ones.
Old May 18, 2024 | 11:57 AM
oddone's Avatar
oddone
sadly i go with what my guy puts on it and is affordable. once i can muster the strength to i am going to check the cap as well i know he went with the brass terminal/contact one when he did tune up not cheap aluminum contact one
