Can anyone tell me my sub model?
Old May 7, 2024 | 08:27 PM
Oldtrucksarebest's Avatar
Oldtrucksarebest
Default Can anyone tell me my sub model?
I have attached the build sheet. Vin# 3B7HF12ZXWG103062. It says sport group, but also says slt interior. Any help is appreciated. Thanks!
File Type: pdf
Old May 7, 2024 | 08:35 PM
Has the SLT designation. But, everywhere I have checked, the only 'model' option offered, was "base"...... The only real difference between any of 'em, is what options they have.
Old May 7, 2024 | 08:51 PM
Oldtrucksarebest
Thanks! I was more worried about replacement body parts. Bumpers, fenders and such. If the only real difference is the options, does this mean body parts should be interchangeable?
Old May 7, 2024 | 08:58 PM
That one has the sport package? So, quad headlamps, right? If that's the case, fenders would have to be for 98 and up, older ones can be modified for the quad headlamps. (mine is 98 sport also, but, it does NOT have the quad lamps..... I think that was a 98.5 thing.) Doors need to come from the same style cab, there are differences between the 2 door, and quad cab doors. Bed just has to be the same length. (and not a dually) as those were all the same. Also, the 3/4 and 1 ton trucks ran to 2002 for the 2nd gen body style. 1500's to 2001. (body panels are the same, within the above constraints.) Also, if you DO have the quad headlamps, the front bumper, and grill will be specific to the 98.5 and up sport package trucks.
Old May 7, 2024 | 09:00 PM
Oldtrucksarebest
No quad lights on mine its an early 98. Door sticker puts it at "97"
Old May 7, 2024 | 09:05 PM
Ah, ok, that opens up the field significantly. Only thing you need to pay attention to is cab style, and bed length. (for bed parts) Everything else is fair game, EXCEPT the bumper/grille from 98.5 and up Sport model trucks. Also, the doors from the 97 and down 'quad cabs' also will not work, as those trucks didn't have the rear suicide doors. Hood, fenders, and such are all the same across the range. (or, at least, no differences you need to worry about. )
Old May 7, 2024 | 09:09 PM
Oldtrucksarebest
Mine is quad cab with no rear door, I always thought this year had them. Or maybe they call it an extended cab. Maybe because my title says "98" but was made August of 97
Old May 7, 2024 | 09:15 PM
They started building the 98's back in June or July of 97.... Car companies are kinda weird that way. I thought all the 98's had the rear doors as well.... mine does.... Wild. That means doors from a single cab truck will work for ya as well, the front doors from the four door cab will not.
Old May 8, 2024 | 03:38 PM
KillerLemming's Avatar
KillerLemming
To add to 98s having rear doors, i have seen some 98s and 99s without the rear doors
Old May 9, 2024 | 06:51 AM
Moparite's Avatar
Moparite
Did They still have the extended cabs with out the doors then? I thought they all where quad cabs if you got the extended cabs.
