46rh input shaft sloppy
Old May 21, 2024 | 11:02 PM
MtnTow's Avatar
MtnTow
Default 46rh input shaft sloppy
Im replacing a flexplate that didnt last very long. I was about to do the front seal when i noticed the input shaft being crooked and sloppy.
You can see the big gap at bottom but not the top. If i wiggle it, it sounds like metal on metal.
is there supposed to be a bushing or something to stop that? Is this unit hooped??
Literally everything going wrong right now.
Old May 22, 2024 | 08:59 AM
Those are supported inside the torque converter, so, I don't think it's too much of an issue. If the trans works properly, run it, see what happens.
Old May 23, 2024 | 03:10 PM
MtnTow's Avatar
MtnTow
Those are supported inside the torque converter, so, I don't think it's too much of an ishsue. If the trans works properly, run it, see what happens.
Ya a few hours of reading confirmed this. Never noticed it before. Just dont want in/out play.
Old May 24, 2024 | 07:52 AM
Moparite's Avatar
Moparite
Converters have bearings inside, The end of the splined shaft is smooth for it to go in a bearing to "center" the shaft.
