Transmission
Old Aug 8, 2024 | 05:19 PM
William_T's Avatar
William_T
Default Transmission
Hello! I have a two-wheel drive, 98 Dodge Ram 2500, 5.9, 12-valve diesel pickup. I need a transmission for the truck. I found a transmission out of a 2002 Dodge Ram 2500 four-wheel drive. Can I put a two-wheel drive tail shaft on the four-wheel drive transmission?
Old Aug 8, 2024 | 05:21 PM
Electronics are not compatible. Governor pressure sensor/solenoid, and trans range sensor (neutral safety switch) are different.
Old Aug 8, 2024 | 07:52 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
Try using car-part.com to find a transmission that will work for your needs. I find that site to be very helpful in finding salvage yards that are likely close to you for finding that type of thing.
