AC Door closes
Old Aug 12, 2024 | 06:48 PM
ShortBox97$'s Avatar
ShortBox97$
Default AC Door closes
1997 Dodge Ram 1500 , step on Gas, door closes and No Air blowing. Let off gas, door opens, Get Air. What do I need to do? Make air flow all the time.
Old Aug 12, 2024 | 06:49 PM
Air likely is flowing, it just switches to the defrost vents. Look in the FAQ/DIY section for 'wild vents', the fix is in there.
Old Aug 12, 2024 | 07:16 PM
ShortBox97$
Default AC Door closes PT2
Is this found in this Form? Wild Vents? Control Button is working for each selection. This Gass thing, you can hear a door closed, no air, till you let off the Gass.
Old Aug 12, 2024 | 07:41 PM
That's wild vents. Yup. The entire system is vacuum controlled, the default setting, when vacuum fails, is defrost. When you step on the gas, manifold vacuum goes down. If your plenum is blown, the problem is even worse.....
FAQ/DIY forum. Link at the top of this one.
