Radio/Speakers
Old Oct 22, 2024 | 10:30 AM
9812v5spdram3500forsale's Avatar
Angry Radio/Speakers
So my head unit went out, I bought a new head unit and hooked it up. No sound. The amp on the back of the unit hooks up, but no sound. Are my speakers blown? How do I reset the wiring in case that is the issue?
Old Oct 22, 2024 | 11:02 AM
What was in there originally? What did you replace it with?
Old Oct 23, 2024 | 02:25 PM
it was a pioneer, and i replaced with a jvc
Old Oct 23, 2024 | 03:43 PM
Recheck your wiring. Does the amp need a separate power feed? Or a trigger wire from the head unit?
Old Oct 23, 2024 | 04:12 PM
not sure.
Old Oct 23, 2024 | 08:12 PM
Need ta figger that stuff out.
Old Oct 24, 2024 | 12:06 PM
ol' grouch's Avatar
ol' grouch
Does the wiring use the proper adapter. I always dread going in when someone just cuts wires. It leads to issues like this down the road. When I replace the factory unit with an aftermarket one, It's plug and play when you use a simple kit.
The Mopar radio wiring from the mid 1980's to 2001 was pretty simple. Keep in mind the signal to the speakers has a positive to and a negative from th speaker. Older radios grounded to the chassis but that changed around 1980 or so.
