Blend Door Actuator.
Old Nov 10, 2024 | 10:47 AM
  #21
Originally Posted by Robt1959
That sticky give out some false information. You do not have to remove the dash to fix a stripped out actuator, just remove the two screws and pull the actuator down. Remove the cracked plastic coupler from the blend door by pulling strait down. Replace with a metal coupler with metal one from http://heatertreater.net/dodge-ram-95-02
It's that back screw that makes it interesting. Some folks have trimmed the carpet a bit, for better access, but, yeah, ya don't need to pull the dash to play with it.
Old Nov 10, 2024 | 12:00 PM
  #22
Robt1959's Avatar
Robt1959
no there is no play. If I put the heater control **** dead center and straight up and down, then start the truck. While the truck is running and I pull the fuse for the blower motor (actuator is on same fuse) then put the fuse back in, then turn **** to full heat it works wonderfully, if I turn **** to full cool it it works wonderfully. But when I turn it back to full heat it stays at full cold. It’s like it gets confused. Brand new actuator, and brand new coupler.Blend door has no play and moves very easily by hand. This isn’t a huge deal, but I can’t stand it that I can’t figure it out.
the back screw wasn’t a problem for me. Just took a little patience. 🙂🙂
