ABS Concern
Old Dec 25, 2024 | 02:21 PM
dannyk11135's Avatar
dannyk11135
Default ABS Concern
Spoiler
Old Dec 25, 2024 | 02:30 PM
You likely only have RWAL, which wasn't really all that effective..... Does the ABS light test when you start the truck?
Old Dec 25, 2024 | 02:31 PM
AtomicDog's Avatar
AtomicDog
You may want to reference the factory service manual for your year truck and have a look at the wiring diagrams that relate to the ABS system, since it sounds like the prior owner may have modified/butchered them. You can download the factory service manual for your year truck here - https://dodgeforum.com/forum/2nd-gen...e-manuals.html
Old Dec 25, 2024 | 07:23 PM
Keith_L's Avatar
Keith_L
I'd be thrilled if all my vehicles didn’t have ABS and no idiot lights warning me the ABS isn't working
Beyond that, I'm no help.
Old Dec 25, 2024 | 07:56 PM
DerTruck's Avatar
DerTruck
Yeah for reasons only the enlightened gods at Chrysler of days past know the rear wheel only ABS is not wired at the underhood fuse box/PDC at all. There are two fuses (14 and 20) in the inside fuse panel and no relays.
Old Dec 25, 2024 | 07:59 PM
Because it is a really simple system.... Just a dump valve, controlled by the PCM. Doesn't need a lot of power.... It's just two solenoids.
Old Dec 25, 2024 | 08:26 PM
dannyk11135
The ABS light does not test when I start the truck…the bulb is still there I checked…unless it burnt.
Old Dec 25, 2024 | 09:25 PM
That would be something to look into. It *should* come on for a few seconds at initial key on.
