1995 dodge ram 360LA swap complete!
Old Jan 16, 2025 | 09:07 PM
ThatRedRam's Avatar
ThatRedRam
it isnt i dont think lol but i may have it laying around
Old Jan 17, 2025 | 09:57 AM
I think it's only three wires, power feed, (I think it's 5 volts, but, might be 8......) ground, and signal to the cluster.
Old Jan 17, 2025 | 09:24 PM
ThatRedRam's Avatar
ThatRedRam
I try that out when weather gets better and my other project gets running. Got the truck put up for winter and got a sn95 mustang 302 turbo im building thats got my main focus
Old Jan 18, 2025 | 03:40 PM
ThatRedRam's Avatar
ThatRedRam
Speedo is driven off the VSS in the tailshaft of the t-case. I suspect if you simply gave that sensor five volts, the speedo would start working. (assuming the rest of the wiring for it is still there......)
the transfer case i have in the truck does not have this sensor. The one i took off the automatic and sold did. So what can i do about that?
Old Jan 18, 2025 | 06:18 PM
You can probably just swap the t-case out, or, worst case, swap the input hub from the new one, to the old one. I *think* there are some differences between manual, and auto, and that is one of 'em..... Does it really matter? Not sure on that. Might be able to just do a straight swap, and call it a day.
Old Jan 19, 2025 | 09:48 AM
Moparite's Avatar
Moparite
I think i read somewhere you can use the abs sensor in the rear also for speed.
Old Jan 20, 2025 | 05:29 PM
ThatRedRam's Avatar
ThatRedRam
yeah id rather not swap the transfer case out. i sold the one i did have with the sensor so i may look into the abs sensor
Old Jan 20, 2025 | 05:39 PM
I suspect the return signal from the rear sensor is gonna be different than what the speedo expects, however, I do believe there are cool little boxes to address that particular problem.
Old Jan 20, 2025 | 05:40 PM
ThatRedRam's Avatar
ThatRedRam
what is this box you speak of?
Old Jan 20, 2025 | 07:15 PM
Moparite's Avatar
Moparite
Do some searching. If it was on a can buss you can get converters to do it. A 95 is not on a can buss. I was researching modern engine swaps in older vehicles and how to convert the can signals to run analog gauges. I think you need something like this, But you need to know pulse rate and what voltage the gauge needs.
Amazon Amazon
