vaccum hose through firewall
Old Jan 18, 2025 | 12:35 PM
madejson's Avatar
madejson
Default vaccum hose through firewall
My 98 dodge Ram 1500 The vacuum hose that goes though the fire wall is broken and I can't pull any more out. I am trying to avoid taking out the top dash bc it is brittle. My question is, does that vacuum line only connect to the climate control or does it connect to a breather valce or something else?
Old Jan 18, 2025 | 12:41 PM
Just for the climate control. If there is enough sticking out, you can just splice it back together with the appropriately sized vacuum line.
Old Jan 18, 2025 | 12:43 PM
madejson's Avatar
madejson
Not enough to splice it. I found another hole on the driver side. I might try to run it through there.
Old Jan 18, 2025 | 12:47 PM
Just needs a good vacuum source. So, however you can manage it.
Old Jan 18, 2025 | 01:18 PM
Keith_L's Avatar
Keith_L
I, too, fear this happening. I loathe even touching the line that runs through the firewall near heater core. Plastic was such a dumb choice here.
Some of the frame lines for the CAD are metal, so like The Million Dollar Man, we have the technology.
Old Jan 18, 2025 | 03:37 PM
My metal lines rusted out, the plastic lines were still good.
But, plastic lines in the engine compartment wasn't the best idea..... of course, they lasted far longer than the warranty, which is all the manufacturer cares about.....
Old Jan 19, 2025 | 09:54 AM
Moparite's Avatar
Moparite
The line runs up to the hvac control(not sure which one). If you can't access the line just run a new one up to the hvac and splice it in.
Old Jan 19, 2025 | 10:56 AM
Keith_L's Avatar
Keith_L
Oh I foresaw that argument and was going to initially say we even have the technology for stainless lines, but that's laughable from an OEM so I refrained.
Old Jan 19, 2025 | 11:11 AM
I am sure they are available in the aftermarket.
Old Jan 19, 2025 | 06:42 PM
madejson's Avatar
madejson
I bought some silicone hose and am going to run it from behind the rubber piece on the hood and though the door hinge area. I found a plug hole I'm going to put it in. Once I do it I can take a pic and show you. Might not be for a while bc I am going abroad for 4 weeks.
