Truck runs but doesn’t drive good
Old Jan 23, 2025 | 10:45 PM
  #21
dodgetruck2's Avatar
dodgetruck2
IF you're running rich and misfiring, i would expect an excessive amount of fresh soot build up. Get it running correctly and drive awhile and then reinspect.
Old Jan 23, 2025 | 10:50 PM
  #22
Marcos2ndgenram's Avatar
Marcos2ndgenram
Oh alright thanks for the info, i might just give up on the 3.9 and go with a 5.9
Old Jan 24, 2025 | 12:01 AM
  #23
AtomicDog's Avatar
AtomicDog
Nothing wrong with a 3.9 V-6. I've got one in a '96 Dodge Dakota with over 300,000 miles on it. After working on it a bit, it's running like a clock, however, it is on an OBD2 PCM...
Old Jan 24, 2025 | 06:21 AM
  #24
2pfspiff's Avatar
2pfspiff
Just out of curiosity, did you install the timing chain or did a garage do it? Was the procedure followed in the manual and all of the marks lined up? I'm wondering if it is out of time with the timing gear installed.
Old Jan 24, 2025 | 07:25 AM
  #25
Marcos2ndgenram
yeah the 3.9 was a great motor and rarely had problems but not its giving me a headache.
Old Jan 24, 2025 | 07:28 AM
  #26
Marcos2ndgenram
2pfspiff, I did the job, made sure both dots where facing each other ( cam dot down and crank dot up), also made sure to torque it to spec, I did follow a You tube video. My marks were unaligned since the cam gear was messed up so I realigned them dots then placed the new chain on.
Old Jan 24, 2025 | 08:30 AM
  #27
dodgetruck2
I apologize if this was covered, but I was unaware of the misaligned timing set. Have you check compression? I wonder about a bent valve
Old Jan 24, 2025 | 09:50 AM
  #28
Running rich?
Old Jan 24, 2025 | 06:28 PM
  #29
Marcos2ndgenram
havent checked the compression but I'll look forward to it.
Old Mar 20, 2025 | 12:42 PM
  #30
Marcos2ndgenram
Checked the compression, 2 and 4 were low and I checked the valves and I had bent push rods.
