Truck runs but doesn’t drive good
Old Jan 22, 2025 | 09:14 PM
Marcos2ndgenram's Avatar
Marcos2ndgenram
Default Truck runs but doesn’t drive good
Hello guys, I have a 1995 dodge ram 1500 3.9L v6 with around 300k miles. It had stopped running a couple weeks ago which was caused by a bad timing chain, replaced it and had also replaced many things including ignition coil, distributor cap, distributor rotor, I also have new coolant sensor, VSS sensor, o2 sensor, and I have good spark plugs. But when I got it running, it idles at around 700-800 rpm’s, but it feels shaky/rough, but it stays on, when in gear it does feel alittle more rough/ shaky and when I turn the steering wheel it loses a lot of power and almost feels like it’s gonna shut off, it drives but when I let off the gas it loses power and stalls, also when I rev it to like 3k rpms or more it turns off completely after letting go of the accelerator. I do have a broken vaccum like that’s infront of the throttle body which ima try and fix tomorrow and see if that’s the problem but I just wanted to get some ideas because I haven’t been able to get it to run good even with moving the distributor to time the ignition with the light. ( I believe the timing is controlled by the computer)
Old Jan 22, 2025 | 09:53 PM
AtomicDog's Avatar
AtomicDog
I'd be sure to fix any vacuum hoses/leaks, as they will certainly cause issues. You may also want to remove and thoroughly clean the throttle body, while installing a new throttle body gasket. Lastly, did you install new copper spark plugs and new spark plug wires?
Old Jan 22, 2025 | 10:01 PM
Marcos2ndgenram
Yes ill make sure to fix that leak, ill give it a cleaning tomorrow and see if it works. when i replaced everything i did it all except the wires, and the spark plugs were platinum from autozone and worked great before it stopped running( plugs were changed maybe 1-2 months before the chain went out.). Ill update u tomorrow see if it runs better.
Old Jan 22, 2025 | 10:34 PM
AtomicDog's Avatar
AtomicDog
Also, try pulling those platinum plugs and install copper plugs to see if it runs better. 5.2/5.9 engines tend to run smoother with cheap copper plugs.. You could have a bad spark plug wire or two as well. Lastly, be sure to check the spark plug firing order to ensure each plug wire is routed correctly.
Old Jan 22, 2025 | 10:37 PM
Marcos2ndgenram
sounds good boss thank you! ill be sure to try that out
Old Jan 23, 2025 | 07:43 AM
dodgetruck2's Avatar
dodgetruck2
Timing is controlled with the computer and cannot be adjusted with a light. If you have loosened the distributor from the block it will need to be synced in with a computer now. Manually adjusting you should be able to find a decent spot for it to run, or if you by chance marked it before adjusting it.
Old Jan 23, 2025 | 06:03 PM
Marcos2ndgenram
I fixed the leak, it changed nothing. I checked the wires with the diagram and they all look correct. tried the copper plugs and it seems to still not run any different . it idles at a good rpm but gives a lot of vibration, also when I rev it up over 3-4 rpms it lets out a big cloud of white smoke, and loses power then regains it shortly.
Old Jan 23, 2025 | 06:08 PM
Marcos2ndgenram
hey dodgetruck2, Do you know if it automatically adjust? I did move it to where it runs decent but it feels like something isn't in sync with everything else
Old Jan 23, 2025 | 06:22 PM
White smoke? That is not a good sign... are you losing any coolant?
Grab the service manual for your truck from here. There is a procedure for setting base fuel sync, which will at least get you close.
Old Jan 23, 2025 | 06:31 PM
Marcos2ndgenram
Not enough for me to notice, oil seems to be kinda dark and more watery than oil even tho I did a fresh oil change. Not sure if the picture is enough to tell anything....
