2500 fuel/starting issues
Old Jan 29, 2025 | 08:04 PM
5.9gopher00's Avatar
5.9gopher00
Default 2500 fuel/starting issues
Hey guys, just recently I’ve been having some issues with my 2000, 2500 Cummins where it takes a couple more cranks to start and also seems to drop 3 ish lbs of fuel pressure upon hard acceleration according to my gauge. Any tips on what it could be? Air leak?
Old Jan 29, 2025 | 08:27 PM
dodgetruck2's Avatar
dodgetruck2
what are you running for fuel system upgrades, what gauge, where is it tied in
Old Jan 29, 2025 | 08:46 PM
5.9gopher00
Fass system, fuel pressure gauge not quite sure where it’s tied in
Old Jan 29, 2025 | 08:53 PM
dodgetruck2
what pressure is it running at idle, full throttle acceleration?
Old Jan 29, 2025 | 08:57 PM
5.9gopher00
idle it’s at 16/17 under hard acceleration it will drop to maybe 13/14 but thing is it runs like a top it just doesn’t like starting well
Old Jan 29, 2025 | 09:01 PM
dodgetruck2
fuel pressure sounds just fine, if the filters have some age that's probably the pressure drop. As far as teh starting you can try tightening the fitting on the back of the head, or replace the seal washers on it
Old Jan 29, 2025 | 09:04 PM
5.9gopher00
fittings on the head are tight, actually started having this issue of hard start since I tightened them back up again, fuel filters are only maybe a month old.
Old Jan 30, 2025 | 05:34 PM
5.9gopher00
Hey guys update, checked my lines going to the head and one was leaking the tiniest bit of fuel which I’m sure is causing my issue. Took it off and cleaned tf out of it with brake clean and it now seals up as it should
Old Jan 30, 2025 | 06:49 PM
Has the problem went away as well?
Old Jan 31, 2025 | 06:39 PM
5.9gopher00
nope but I believe it has something to do with the return lines
