Heat Issue
Old Jan 31, 2025 | 06:21 PM
Wolfen1086's Avatar
Wolfen1086
Default Heat Issue
ok when its 70 outside my 96 ram 2500 V10 will burn you out of the truck, when its 30 outside my ram 2500 with freeze your *** off, why?
Old Jan 31, 2025 | 07:14 PM
Moparite's Avatar
Moparite
What's the coolant temp in both cases?
Old Feb 1, 2025 | 12:42 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
I used to put a piece of cardboard to block off some of the air going thru the radiator. I blocked 1/2 of the radiator off on my 440 when temps got below zero. Yes, I had to use a big jump starter to get it spin over at 10 below zero.
Old Feb 2, 2025 | 03:06 PM
Wolfen1086's Avatar
Wolfen1086
I got 145 on the inlet and 140 on the outlet, 195 at eth thermostat and 18o upper and lower hoses watch pump is one year old from NAPA designed for e V10 1996
Old Feb 4, 2025 | 12:42 PM
ol' grouch's Avatar
ol' grouch
Blend doors are notorious for failing on these trucks. When you move the controls, can you hear movement inside the dash?
Old Feb 5, 2025 | 08:13 AM
Moparite's Avatar
Moparite
If it's not a issue in the hvac box then it's a issue with the heater core. I have seen the boxes half way filled up with tree debris blocking air flow.
Old Feb 7, 2025 | 05:32 PM
Wolfen1086's Avatar
Wolfen1086
Yes. mine are Vacuum actuated I have seen all three actuators working
Old Feb 7, 2025 | 05:34 PM
Wolfen1086's Avatar
Wolfen1086
Yea, I cleaned out the box with a borescope and a vaccumcleaner its an old farm truck used only in the spring planting season through harvest season, that's why I want to hook up my water nose to the heater noses, I had a Dakota that had no heat I cleaned the heater core out and a ton of black gunk came out, so I figure what the heck right? it cant gunk to back flush it
Old Feb 7, 2025 | 06:19 PM
The actuators may be moving, but are the DOORS moving. Blend door likes to separate from its axle. It's also mechanically moved via a cable to the top of the heater box.... no actuator for that one.
Old Feb 7, 2025 | 06:27 PM
Moparite's Avatar
Moparite
The blend door is cable operated on your year. All the other doors are vacuum.
