‘01 1500 320a alternator
Old Feb 3, 2025 | 07:03 PM
Leebushong's Avatar
Leebushong
Default ‘01 1500 320a alternator
Good evening, all!
Anyone installed a high output alternator on their ride? I run a farm and my mobile power needs aren’t met by my truck (maybe I could bring a gas generator with me, but that’s no fun). If you’ve installed a high output alternator (117 is stock and I want to go up to 320a), what modifications did you make? What lessons did you learn?
Power will go to a large inverter and from there to machinery.
To the mods: if this is in the wrong place, I apologize. Please move it if you feel it’s necessary.
Thanks!
Old Feb 3, 2025 | 07:33 PM
Moparite's Avatar
Moparite
The stock wiring is not going to work for that kind of amperage. I would suggest running two batteries and run new wiring for the amount of amps you will be working with. The stock fuse you can't go past a certain amperage(They don't make that style fuse in a larger amperage) I don't recall what it is but believe it's around 200A. So a upgraded fuse holder should be used also.
Old Feb 4, 2025 | 03:35 PM
adukart's Avatar
adukart
There was a factory dual alternator option. I have never seen one but I'm sure it could be done.
Old Feb 4, 2025 | 05:36 PM
Didn't you have to give up A/C for that though?
Old Feb 5, 2025 | 08:03 AM
Moparite's Avatar
Moparite
I suppose that is another option, But would still need to run wiring/regulator for the second alternator.
https://www.southerncustomsla.com/pr...ternator-kit/9
Old Feb 6, 2025 | 08:53 AM
adukart's Avatar
adukart
Idk, my v10 has the spot for it above the air pump. I am not sure how it was handled on the cummins and v8.
Old Feb 6, 2025 | 06:21 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
The Premier Power Welder uses a 200 amp alternator. Need a welder? Just showing the 200 amp runs the welder with no problems. I was pushing 2000 watts RMS with the stock alternator when I had my 04 Corvette.
https://premierpowerwelder.com/shop/...welder-system/
