Radiator transmission cooler supply bolt
Old Feb 12, 2025 | 10:30 AM
rubiksmind's Avatar
rubiksmind
Originally Posted by Keith_L
So it's the male threads visible that are boogered? It appears that way but the photo is not exactly high resolution. I'd run a die over them even though it looks like they're done for. I have no idea what thread pitch would be -- I just figure that out w calipers and thread pitch gauges.
But the brass fitting should unthread, unless the hex is just there to allow you to hold it when tightening?
On many radiators (eg '06-10 Exploders) the cooler line discos are notorious and you often just have to unthread the whole fitting from the radiator -- it's simply easier and safer.
Unfortunately, I don’t possess the tool nor knowledge to use a die.. I just haven’t got that far yet. But I’m pretty sure even with a die you’d have to move down to the next size anyway..
I definitely think it would be easier and safer if that fitting unthreaded but I’m certain it doesn’t.
Old Feb 12, 2025 | 10:32 AM
rubiksmind's Avatar
rubiksmind
If it works, run with it.
I just check it every time I park, and it did stop my leak so there’s that.. lmao.
