Lost on a No BuS situation
Old Apr 11, 2025 | 12:28 PM
ExtremeBopper's Avatar
ExtremeBopper
Default Lost on a No BuS situation
I drove to autozone to do my shift while I replaced the plenum plate on my 01 Ram 2500 with the 5.9. I got everything back together and found out I was getting no fuel pump and no spark. A buddy found I was getting the no bus message so i’ve been rechecking everything I did and figured out I pinched the camshaft position sensor. I replaced that but i’m still getting the message. I’m getting 5v to all sensors and a good ground. I can’t connect to the obd2 port to scan codes but i am getting power to the 3 and 11 pin. All fuses and relays are good. I’m completely stumped as I’ve gone through most of these forums.
Old Apr 11, 2025 | 12:41 PM
Did you pinch the harness side of the cam sensor wiring as well???
Old Apr 11, 2025 | 12:49 PM
ExtremeBopper
No, only the pigtail side
Old Apr 11, 2025 | 01:16 PM
What brand cam sensor did you buy? These trucks are notorious for being REALLY picky about their sensors..... That, and part quality in general has declined dramatically in the last couple years.... Too many mergers/buyouts....
Unlplug the cam sensor, turn the ignition on, is the no-bus gone??
Old Apr 11, 2025 | 01:18 PM
ExtremeBopper
Still there, it was the TEMKKEN brand. Got it off amazon
Old Apr 11, 2025 | 01:23 PM
Never heard of 'em.
Ok, there are a bunch of sensors on the five volt circuit... including the O2 sensors, so, start unplugging them one at a time, and see if your dash comes back to life.
Old May 6, 2025 | 05:44 PM
ExtremeBopper
Ended up being the computer, thanks man
Old May 7, 2025 | 09:10 AM
Keith_L's Avatar
Keith_L
How did you remedy that? Used or aftermarket or something else?
