crank no start
Old May 29, 2025 | 01:49 AM
rylan's Avatar
rylan
okay ill check that but i found out the solenoid was for a winch on the back of the truck in the past but i think my problem is ground. ive done lots of research and reading through the repair manual but i cant figure out where the pcm ground is
Old May 29, 2025 | 07:47 AM
Moparite's Avatar
Moparite
Look at the wiring diagrams here for your year truck.
Old May 31, 2025 | 12:58 AM
rylan's Avatar
rylan
i took a look at that. i also hooked up an obd1 reader today and its one of the ones where you also hook it up to power from the battery and everything came on asd clicked engine came on and it started a little bit so i think i have a bad ground or power for the pcm
Old Jun 3, 2025 | 03:48 PM
Confusedram's Avatar
Confusedram
Default 95 ram thinks it’s a 99
I’ve got a 95 ram 1500 5.9 with a complete harness out of a 99 yes odd but it’s ran in the truck for 5 years. I’ve replaced the crank sensor cap rotor button and pickup in the distributor will crank builds fuel pressure
thanks for any feedback
Old Jun 3, 2025 | 03:58 PM
That's gotta be a wiring nightmare, considering how much changed over the years. What year PCM are you using? Will your scanner talk to it? Check engine lite on?
Old Jun 3, 2025 | 04:03 PM
Confusedram
it’s using a 98-99 truck pcm . No will not talk to the early obd check engine light is on but truck has ran awesome for years
Old Jun 3, 2025 | 04:20 PM
Did you install the OBDII interface to plug into??? Need to know what the PCM is whining about, in order to fix it....I am REALLY surprised someone actually got that to work properly.....
