Transmission Temp Monitoring Through OBD2?
Old Jun 13, 2025 | 08:23 AM
latkelarry's Avatar
latkelarry
That's where it was on the pre-96 trucks that actually had a sensor.
I *think* I have seen gauges that will read from the diagnostic port as well, but, I don't recall where......
Would this type of sensor/gauge combo plug right into the diagnostic port? I think this one is different than the in line sensor.
Old Jun 13, 2025 | 09:21 AM
HeikIlm's Avatar
HeikIlm
Nevermind.
Old Jun 13, 2025 | 09:38 AM
Comes with the sensor, but, no clue how the sensor installs.....
Old Jun 13, 2025 | 11:32 AM
HeikIlm's Avatar
HeikIlm
Sensor has 1/8-27 NPT thread.
Old Jun 13, 2025 | 11:33 AM
Screw it into one of the pressure test ports?
Old Jun 13, 2025 | 12:00 PM
AtomicDog's Avatar
AtomicDog
Just for my own understanding, does anyone have a photo of the side of the transmission showing the port where the transmission temperature sensor might screw into?
Old Jun 13, 2025 | 12:09 PM
latkelarry's Avatar
latkelarry
Although on some quite old posts on this forum folks had suggested others to not do that as something about the temperature of the fluid not being the most exact in that spot and the T off the return line would be better? I guess I’ll do some more digging, thankfully I have ten days or so before I can get to working on this so I have time, just wanted to get my ducks in a row ahead of time
Old Jun 13, 2025 | 01:05 PM
You want to T off the line going OUT to the coolers. As close to the trans as you can get, for the most accurate reading.
Old Jun 13, 2025 | 05:51 PM
Moparite's Avatar
Moparite
I think I seen an original trans line with the cooler. It just had another piece of tube coming out with the fitting on the end. It was right after the bend coming out of the trans.
Old Jun 13, 2025 | 05:53 PM
Yeah, that's for 95 and older with the trans temp sensor. Part of one of the heavy duty towing packages I think. I don't see why you wouldn't be able to use that line on a newer trans though...... That is, assuming you can even find one.
