Rust repair/boxed frame
Old Jun 20, 2025 | 09:30 AM
HeikIlm's Avatar
HeikIlm
Default Rust repair/boxed frame
I guess it's a known issue that these trucks like to rot their frame behind the fuel tank. My truck also has a small crack on RH frame rail, between the cab and the bed. I've welded that at least once.
Left side is no brainer, I already have the material to fix that, but I was thinking to make both sides stronger.
I've thought about boxing the C-frame from under the cab all the way to rear spring front hanger.
But my concern is that I might create another weak spot somewhere else, as the frame is designed to flex, and every once in a while I do some off-roading.
Or maybe I just weld some flat stock to lower lip of the C.
To box or not to box?
Old Jun 20, 2025 | 09:34 AM
If the frame is more rigid, then rough terrain will just tend more toward lifting a wheel, rather than twisting the frame. I could see circumstances where they wouldn't really be desirable... but, having your frame doing the pretzel thing probably ain't the best either. With good suspension articulation, seems like it'd be a non-issue.
Old Jun 20, 2025 | 10:05 AM
Keith_L's Avatar
Keith_L
I don't know but of course want pics of whatever you do!
Old Jun 20, 2025 | 01:44 PM
HeikIlm's Avatar
HeikIlm
This is something I'm going to tune, I really don't like how the rear rides empty. But we'll see how it turns out.
I have a flatbed on my truck, which also strenghtens the rear part of the frame, and I need to make couple of changes which probably make it even more rigid.
Old Jun 20, 2025 | 01:46 PM
HeikIlm's Avatar
HeikIlm
I sure will take pictures
Old Jun 22, 2025 | 05:30 PM
Keith_L's Avatar
Keith_L
I've always been very skeptical of Sulastic shackles but some people say they help. I don't know if they technically make a 2nd Gen application....and apparently I don't care enough to do a quick web search.
Old Aug 12, 2025 | 07:57 AM
HeikIlm's Avatar
HeikIlm
I did look up the Sulastic shackles. And boy they are expensive! $530 a set, and after shipping, taxes and customs, they add up to a grand! Though they look well built and sturdy, but still they have limited lifespan.
Old Aug 12, 2025 | 10:07 AM
Interesting idea, but, I just don't see the cost/benefit ratio for those.......
Old Aug 12, 2025 | 03:16 PM
HeikIlm's Avatar
HeikIlm
Did some reading, and apprently they take out the harsness from the rear suspension. Still too expensive, but I found similar product from Alibaba for $60/piece. Welded part vs Sulastics cast part.
Old Aug 12, 2025 | 06:14 PM
Moparite's Avatar
Moparite
I'd opt for duel shocks than buy them. You still have the front mount so in theory it's only helping to eliminate 50% of the harshness. This thread reminds me of an episode of American Hot Rod. There was a Model A frame that I believe was one of the workers. Boyd told him to box the frame but he wanted to keep it all original. There was a big argument over it. Cracks start from fatigue (flexing) so keeping it from "flexing" should greatly reduce the chance of it cracking.
