front lower shock bolt
Old Aug 11, 2025 | 10:29 AM
oddone's Avatar
oddone
Originally Posted by Moparite
Ok did some digging, Bolt # is 6502 818 it is a M14x2.00x80.00 Just look up a flange bolt and readily available. The nuts # 6502 817 I found here. Also found something similar with the same thread here. And yes I did a Google search for flag(or tab) nuts 14x2 and next to nothing comes up. McMasterCarr doesn't have them. If you don't want to pay the price just get regular flange nuts and make the tab out of flat stock, Drill a hole about the size of the nut(outer hex). Beat (or press) it on then weld it. Lastly as mentioned a 14mm bolt diameter is 0.5512 in inches. A 9/16 bolt diameter is 0.5625 so a 9/16 is a slight bit bigger but probably would work. May want to try one out first to be sure. And if you live in the rust belt put never seize on the threads!
looking like the place i ordered them from might have been a bad idea a good portion of their reviews are not good and so far it's been a week and for 2 bolts and 2nuts keeps showing ready to ship and all the mopar parts sites i am seeing look the same as them
