transfer case noise?
Old Oct 29, 2025 | 11:10 PM
caden stinson's Avatar
caden stinson
Default transfer case noise?
I have a 1999 Dodge ram 1500 4 x 4 and the issue I’m having is when I put it and drive or reverse from Park or neutral it takes a second to engage more so in drive than reverse, but when it does engage, it will make a clunking noise. I just recently swapped the transmission and I reused my old transfer case and before swapping the transmission it never had this issue
Old Oct 30, 2025 | 09:36 AM
Is it the trans, or the t-case making the noise? Some chain slop in the t-case is pretty normal, given it's age......
Old Oct 30, 2025 | 03:38 PM
caden stinson
I'm not sure if it's in the trans or transfer case
Old Oct 30, 2025 | 06:17 PM
What was the trans from? Used? Mileage?
Old Oct 30, 2025 | 09:16 PM
caden stinson
Came from a running and driving 2001 dodge. It is used 176k miles and the transfer case has 148k miles. I jacked the truck up today and put it in drive and there is a clicking noise coming from the transfer case so I believe that's the culprit
Old Oct 31, 2025 | 07:31 AM
I think you are going to have issues with an electronics mismatch..... I believe they changed in 2000.... though, it *might* have been 99...... Is the check engine lite on? Trans temp lite?
Check the shift linkage for the t-case, and make sure it is fully engaged in 2 hi.....
Old Oct 31, 2025 | 10:27 AM
Keith_L's Avatar
Keith_L
That's not a transfer case noise. In 2wd it's just a solid pass-through shaft
Old Nov 2, 2025 | 02:00 PM
caden stinson
The trans temp light and O/d off were both on, I temporarily swapped to a 2001 ecm until I get the 99 sensors,I'll check the linkage on transfer case
