5.9 360 camshaft position sensor
Old Jan 2, 2026 | 02:03 PM
Waylon#0421's Avatar
Waylon#0421
Default 5.9 360 camshaft position sensor
Anyone know the part number for the camshaft position sensor on a 5.9 360. Ive tryed everywhere and all i can find is the sensor for a 5.9 cummins.
Old Jan 2, 2026 | 02:27 PM
What year?
Old Jan 2, 2026 | 05:44 PM
Waylon#0421
What year?
The truck is a 2001
Old Jan 2, 2026 | 08:46 PM
Part number is 56028143. Listed as a switch in the mopar parts book. Parts store probably calls it a pickup coil. Discontinued from Mopar....
Old Jan 2, 2026 | 08:49 PM
dodgetruck2's Avatar
dodgetruck2
Yes, this has to be one of the worst part terminology disasters I've worked with, in the end pickup coil usually delivers
Old Jan 2, 2026 | 09:04 PM
Waylon#0421
Perfect thank you so much
Old Jan 2, 2026 | 09:11 PM
Waylon#0421
Any advice for how to remove the rotor and keep the correct timing?
Old Jan 2, 2026 | 09:40 PM
No issues there, just pull the little feller off, replace the sensor/switch/pickupcoil/whateveryawannacallit, stick the rotor back on. It's keyed, so only goes on one way.
Old Jan 2, 2026 | 10:06 PM
AtomicDog's Avatar
AtomicDog
The rotor tends to fit on the shaft pretty tight, but it just pulls upward to get it off. As long as you don't move the distributor, timing will not be affected.
Old Jan 4, 2026 | 09:31 AM
Waylon#0421
Alrighty thank yall very much
