2001 Dodge Ram 1500 5.2L Laramie SLT ignition problems
Old Jan 4, 2026 | 07:37 PM
Ttklinger2007's Avatar
Ttklinger2007
Default 2001 Dodge Ram 1500 5.2L Laramie SLT ignition problems
Backstory: Truck has 314,000 miles, engine was replaced at 250,000. I’ve been working on my truck for two days now, it’s 2wd and my truck was not getting traction so my smart self decided to put more power in to see if it’ll catch and blew my transmission line to the radiator. Reconnected the line and put fluid in as I didn’t have problems shifting gears, truck begins backfiring and dying. Drive with that happening to get to safe spot off the side of the road. Realize once truck is home that ignition tune up was never done on the new engine. Replaced spark plugs, wires, rotor and cap. Truck cranks and fires but dies immediately after. Have no idea what to do next whether it’s the timing or something electrical shorted out from the transmission fluid.
Old Jan 4, 2026 | 07:50 PM
If you hold your foot on the gas, will it stay running?
Old Jan 4, 2026 | 07:55 PM
Ttklinger2007
Yes and doesn’t backfire or pop
Old Jan 4, 2026 | 08:16 PM
Clean the throttle body, and reset the computer.
Old Jan 4, 2026 | 09:58 PM
AtomicDog's Avatar
AtomicDog
If you hook up an OBD2 scanner to your OBD2 port under the dash, do you get any stored or pending codes?
Old Jan 5, 2026 | 09:01 AM
dodgetruck2's Avatar
dodgetruck2
2001 should be capable of the key trick, turn the key on/off/on/off/on/off/on the odometer should flash p codes
Old Jan 5, 2026 | 01:21 PM
Ttklinger2007
I ran a code reader before changing everything over and had exhaust leak, manufacturer control, and o2 sensor codes. Cleared them to see if it would start after the tune up.
Old Jan 5, 2026 | 01:28 PM
Ttklinger2007
Yes it did, P0037 and my reader also has a P0601 Internal Control Module Memory check sum error, which also showed up on my first read as well I forgot to mention
Old Jan 5, 2026 | 02:34 PM
Ttklinger2007
I reset the computer, still wasn’t starting. Put my foot on the gas and it stays on but backfires and runs rough
Old Jan 5, 2026 | 04:36 PM
The P0601 code says bad PCM.
