5.9 V8 Injectors
Old Jan 23, 2026 | 10:20 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Default 5.9 V8 Injectors
Looking for stock size injectors. Anybody have any recommendations? I don't want cheap China knockoffs that suck. I believe I have a leaking injector causing a long start after sitting.
P.S. Hey you fuel pump has been changed :b
Old Jan 24, 2026 | 07:28 AM
OEM. Tried rock auto?
Old Jan 24, 2026 | 12:31 PM
Moparite's Avatar
Moparite
I finally found a video showing differences between (in this case) 4 hole vs 12 hole injectors dyno tests. There are tons of videos showing spray patterns and flow but no real dyno specs to see. I'm sure there are variables that they didn't test like flow rate differences(non matched) etc. If you watch to the end i disagree about K&N vs paper. They were probably testing a dirty K&N. Again plenty of videos to watch on that subject also. There are probably places where you can get stock injectors cleaned and flow matched vs ebay and RA.
Old Jan 24, 2026 | 03:01 PM
From what I understand, the stock injectors, which are one hole... fire a stream of fuel at the backside of the rather hot intake valve, which flashes the fuel into a vapor. (and also cools the valve....) Which accomplishes pretty much the same thing, as multi-hole injectors.
Old Jan 25, 2026 | 08:57 AM
Moparite's Avatar
Moparite
With the tests i seen the multi hole ones flow more and atomize better than the single hole ones. Does this get you better fuel economy or performance is the question?
Old Jan 25, 2026 | 09:14 AM
I doubt that it makes a noticeable difference. Maybe if you were racing, it would be a worthwhile 'upgrade', but, for a daily driver? Nope. Spend your money elsewhere.
Old Jan 25, 2026 | 06:32 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
Not my truck but I've replaced the 6 on a 4.0, and a 02 BMW X5 I replaced all 8. I get the flow matched to 1% and 4 hole, refurbished. They ran smoother a bit but nothing to write home about. If they gave any HP or extra fuel milage it wasn't noticeable to me.
Old Jan 25, 2026 | 09:59 PM
ol' grouch's Avatar
ol' grouch
When I did my plenum repair, I replaced all the injectors with stock replacement units. I changed so much when I did the job I don't know if they made a difference but the truck runs and idles smooth compared to before. Then again, it was a sick engine before.
Old Jan 27, 2026 | 03:53 AM
MoparFanatic21
Issue I have is extended crank and bucking under load. I did the plenum. Still have the check engine light code for an evap leak, but can't find it with my smoke machine.
Old Jan 27, 2026 | 10:16 AM
ol' grouch's Avatar
ol' grouch
There is something ****ling at the back of my mind. I know I had to make a gasket for the throttle body on the intake so I have a very low idle when first started. A block or two down the road it goes away.
