No front park/marker lights
Old Apr 18, 2026 | 12:18 AM
  #21
5.9gopher00's Avatar
5.9gopher00
Originally Posted by DerTruck
Yes that's the one. Chrysler calls it a "connector" I guess because it connects to the bulb. Note there are only three wires although the bulb has 4 pins, the two grounds are tied together in the "connector".
yeah I’ll check that as soon as I can get to it. Not sure if it matters or not but I’ve had issues with my multifunction switch, left turn signal indicator is on all the time. I know the park and turn circuit is together but not sure if that switch plays a part to it?
Old Apr 20, 2026 | 07:13 PM
  #22
5.9gopher00
Edit: thank you everyone for the help. After looking through countless wiring diagrams I found my G100 ground to be cooked. It checked out to be good with a test light but half the wires weren’t attached anymore. After redoing the ground properly I now have front park lights hopefully this helps someone with this issue in the future
Old Apr 20, 2026 | 09:41 PM
  #23
See Post 11.
Been there, done that, got the t-shirt. And a few scars to go with it.......
