1997 1500 electric fire under hood
Old May 8, 2026 | 02:38 PM
Opocolypze's Avatar
Opocolypze
Default 1997 1500 electric fire under hood
Welcome to my nightmare. 97 ram 1500 5.9l, Short version had a meltdown in or around the distributor and it took out the ecm, engine, transmission harness across the firewall. Got a harness from a salvage yard 98 ..... now I have no power to the fuel pump relay and no spark it does crank over nicely just won't run. Any help would be greatly appreciated.
thank you
Old May 8, 2026 | 04:32 PM
Hehehe44's Avatar
Hehehe44
thank you
hey that freaking sucks man have you checked the wiring that goes to the fuses and have you checked fuses in the cab, that could be a reason why it is not working. Any chance you have pictures of what happened also check spark pulgs/wires if you haven't
Old May 8, 2026 | 10:12 PM
DerTruck's Avatar
DerTruck
Fuse 9 in the inside panel powers the control side for the fuel pump relay and the ASD relay. Fuse 8 in the PDC provides power to the fuel pump and the PCM. Start with these two.
Old May 9, 2026 | 08:17 AM
There were a LOT of changes from 97 to 98 in the way things worked, and I suspect the wiring harnesses are not interchangeable.
