Heater Confusion
Old Jan 27, 2006 | 08:03 PM
Drifter97's Avatar
Drifter97
Default Heater Confusion
Alright ever since I bought this truck, no matter how long it's running for i still only have mild-luck warm heat coming out, although my guage indicated its running at 200 degrees. I have flushed the coolant and replaced the radiator cap, but still no heat. My heater core doesn't leak. I checked my fuses and where the panel indicates the blower motor fuse would be, it says NA, so does that mean I just do not have a blower motor, and I don't have a heater? It's been cold as hell here lately, and my windows aren't defrosting before work. I was thinking of replacing the thermostat but I want to know if that would fi my heater, or do I not even have one??
Old Jan 28, 2006 | 02:05 AM
REDKNOB's Avatar
REDKNOB
Default RE: Heater Confusion
not sure why the fuse panel says n/a but does the fan blow at different speeds when turned up? Sounds like you have done all you can do short of replacing the thermostat, and YES you do have one. Replace it, and get a 180 not the stock replacement.
Old Jan 28, 2006 | 02:14 AM
mikecjn's Avatar
mikecjn
You may want to try to flush the heater core itself also. There may be crap in it that is not letting you get good water flow thru it leaving you with the luke warm air.
Old Jan 28, 2006 | 04:50 AM
Drifter97's Avatar
Drifter97
No, it doesnt seem to change at all even if i crank my heater all the way up, it barely warms up the slightest bit.
Old Jan 28, 2006 | 05:05 AM
shott8283's Avatar
shott8283
i think he ment the speed of the blower motor...does that change speed when you select low to high ....i had the same problem and i flushed my coolant good-n-tight and put a peice of card board on the rad ... helps out during the winter
Old Jan 28, 2006 | 12:30 PM
brute98's Avatar
brute98
Had this happen to me last week temporarily. No blower at all. Give your fuses a good push in all the way and check the connector at the blower because they can get loose sometimes.
Old Jan 28, 2006 | 06:04 PM
badram1500's Avatar
badram1500
ran into this on a car once, the blend air door was stuck open. This door lets outside air in when the heater isn't on full bore. With the door stuck open it was letting cold air in no matter what the heater control was telling it to do. just a thought
Old Sep 17, 2006 | 09:21 PM
stussi's Avatar
stussi
where are all of the blend air doors, and how many are there. i have a 98 1500ram, with luke warm air coming out. my dad and i checked the heating core is hot enough that you cant even touch it, and the blower motor works fine. it blows out enough air but it is only luke warm. my dad thinks there is a stuck blend door and we dont know where all of them are we only know of the one behind the glove compartment, and that one is for recirculation.
