Looking Need Help Motor Wise 5.9 Ram
Old Feb 1, 2006 | 10:17 PM
rmc5043's Avatar
rmc5043
Default Looking Need Help Motor Wise 5.9 Ram
I have a ram and it burns oil and knocks sometimes. So my question is that I need to fix it and im wondering what you guys think is gonna be wrong when i tear it apart? I was also wondering if there is sometihng like a crate rebuild where i can do that to my motor and fix it and get higher performance then stock? but i dont wanna bore the block and i dont wanna buy a new crate motor.
Old Feb 1, 2006 | 10:37 PM
bamory's Avatar
bamory
Default RE: Looking Need Help Motor Wise 5.9 Ram
New set of heads/intake /TB/cam you can even go as far as putting new rings in. Don't go to radical, but you can tie up alot of cash at once. As for the burning oil, could be valve seals, rings or a serious intake gasket leak, have you looked inside your TB yet for pooling oil?
Old Feb 1, 2006 | 10:45 PM
rmc5043's Avatar
rmc5043
no i havent looked down the tb yet i live 4.5 hours away from my truck right now because of school, But as soon as spring break comes along or the end of the school year ill be putting it in the garage and tearing it apart. Id like to get it fixed and like 50 more horses
Old Feb 1, 2006 | 11:00 PM
bamory's Avatar
bamory
50 HP ? Good luck with that.
Old Feb 1, 2006 | 11:23 PM
rmc5043's Avatar
rmc5043
well maybe 50 was exagerating it haha but more
Old Feb 1, 2006 | 11:41 PM
shott8283's Avatar
shott8283
50 isnt that far off... r/t heads cam RR intake headers and a program should net you close to that
Old Feb 2, 2006 | 12:58 AM
Socha_62's Avatar
Socha_62
PLENUM! I'll put money on it
Old Feb 2, 2006 | 01:04 AM
rmc5043's Avatar
rmc5043
the plenum coulsd possibly solve the oil burning problem but i t wouldnt solve the knocking would it? i cant imagine that it would
Old Feb 2, 2006 | 01:45 AM
rmc5043's Avatar
rmc5043
Also who makes or what is the rr intake im familiar with intake stuff but when you said rr nothing came to mind
Old Feb 2, 2006 | 02:13 AM
Dodge4x4810's Avatar
Dodge4x4810
PLENUM, look down the butterflies in the throttle body with a mirror and see is there is any oil pooling in. How many miles on it, the valve seals are known to last a very long time in these and chances are it is not the rings. If it lets out a puff of blue smoke (oil burning) on startup then it is most likely your plenum gasket. If it is not that, which it probably is, then you should probably do a compression check to check the rings.
