Old Aug 5, 2015, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brakes
Print Wikipost
ABS and brake light on
Old Oct 22, 2013 | 12:46 PM
  #51
Most of the little code readers won't do ABS codes. Need to go to a shop, or someone that has a "real" scan tool for those.
Could be brake switch, e-brake switch, or any of a number of other things as well.
Old Oct 22, 2013 | 02:35 PM
  #52
edboyles's Avatar
edboyles
I have checked the emergency brake switch and it is fine. I went to test the Brake pedal switch but it is 6 pins, so not sure which pins are which without replacing the switch.
What else to check?
Old Oct 22, 2013 | 02:46 PM
  #53
Get the codes read, and then you will know exactly what it is whining about.
Old Aug 29, 2014 | 05:21 PM
  #54
kgilhooley31's Avatar
kgilhooley31
Default ABS Reader
Any suggestions on where to go to get abs read for free? I had some idiot at autozone try to swear to me his code reader read abs but I knew it didn't. I absolutely know my abs does not work. I even replaced the RWAL sensor and same. I can't find anyone to scan me for free
Old Aug 29, 2014 | 06:53 PM
  #55
2 or 4 wheel ABS?
Old Aug 29, 2014 | 06:56 PM
  #56
kgilhooley31
Gotta be 2...havent found any wires or sensors upfront when had the wheels off.
Old Aug 29, 2014 | 07:16 PM
  #57
If your speedo is working properly, then likely the rear wheel speed sensor is doing its job. That said, there have been folks that bought the 'cheap' one, and still had issues. Just because a part is 'new', does not necessarily imply that it will work...... (on your truck, speedo gets it's cue from the same sensor though. So, if speedo is working, it's prolly fine.)
May be a bad brake lite switch as well. I think there are some troubleshooting steps in the the FSM, which you can download from here.
Old Aug 29, 2014 | 07:38 PM
  #58
kgilhooley31
What about the VSS going bad? Now the rwal one
Old Aug 30, 2014 | 09:59 AM
  #59
You have an output speed sensor on the trans, but, if it were going bad, first symptoms you would see is strange shifting behavior.
Old Aug 30, 2014 | 10:11 AM
  #60
kgilhooley31
Hm. Also the abs and brake light don't always come right on when the vehicle is started. Some times they won't come on unless I have to do a hard brake.
